09-04-2019, 01:47 PM | #1 |
Wiring harness question
I discovered an unconnected grey wire coming out of the firewall, engine compartment side. I haven't been able to easily trace it on the cab side of the firewall, as it's in a taped bundle. It is in the ammeter harness, which seems to only have 2 wires (green, brown, going to the resistor) in the assembly book, not 3. It is grey and has "28" stamped on it. I called Lectric Limited, but they weren't able to help. Does anyone know what this wire is?
09-04-2019, 07:24 PM | #2 |
Re: Wiring harness question
It looks like an under hood light was an option on these trucks. Since the dash bulb wires are grey, I wonder if this unconnected lead was for this option?
09-05-2019, 01:23 PM | #3 |
coolant sensor wire, 55 has a mechanical gauge, but the harness is probably 55-59
the end is similar to coolant sensor on the 56-59
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-09-2019, 03:28 PM | #4 |
I agree with Ogre- That connector looks like the type on that fits my coolant temp. sensor on my '59. The 55 2nd used a capillary tube style coolant temp set up.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1 |
