Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-10-2019, 10:18 PM   #10
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: The never ending K5 Build LS Swap
For the LS engine mount, I ended up going with Dirty Dingo. I did extensive research on this subject and after talking directly to Pacific Fabrication and Dirty Dingo I ended up with the latter.
The reason I went with the DD is that they guaranteed me that my stock height leaf springs wouldn't be an issue with the cross member hitting the top of the pumpkin on the differential. (We Shall See!) The only thing I didn't like about the DD is I am going to have to make new brake lines and re-route. The Pacific Fab has cut-outs or notches if you will, in their version and I would have gone with theirs if it didn't require at least a 2" lift.
The install was pretty easy and they provide you with detailed instructions that are easy to follow.
I had to bend my existing line to allow the cross member to fit. It's binding on the frame so a new custom line will go in it's place.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
