Old 07-21-2018, 07:57 PM   #1
69heavychevy
69heavychevy's Avatar
Aftermarket proportioning valve leaking
I replaced my old proportioning valve about 6 months ago with an aftermarket unit. The other day while driving I noticed my brake pedal was getting a little mushy. Popped the hood and saw brake fluid all over the frame crossbrace where the valve bolts too.
Leak was coming from the tiny whole that's on the fitting leading to the rear brakes.
My question is whether this was caused by abnormal pressure in my braking system, maybe some sort of restriction in the rear brakes. I did a complete overhaul on my front and rear brakes last year.
I'm also running hydroboost so I don't know if that could also be an issue?
Or maybe it just a defective unit? I bought from CPP if that makes a difference.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 07-21-2018, 09:26 PM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Aftermarket proportioning valve leaking
I've gone thru these CPP valves many times, and yes they do leak. BUT, if you tell CPP of this issue, I believe they still build a rebuild kit you can do yourself. it's been years that I did this and they did sell one, they just don't let everyone know about the kit. (another fine product from overseas)
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 07-23-2018, 08:51 PM   #3
MikeB
MikeB's Avatar
Call CPP. They'll tell you they've never heard of the problem before, and will somehow blame it on you. Designed in CA, made cheaply in China.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-14-2019, 09:17 PM   #4
rvrfoot
How did you fix the problem?
rvrfoot is offline   Reply With Quote
