67-72 SBC motor mounts
I am looking for a set of 1967-1972 c10 motor mounts. They must be the ones that use the front or forward set of holes in the frame.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353 |
Re: 67-72 SBC motor mounts
for bb or sb? I believe they are all the same even for 6cyl......just flip sides....put driver on passenger and passenger on driver side.....i may be wrong but try it.....
SBC. I will try flipping them. Thanks!
![]() Join Date: Oct 2009
They might work flipping sides but they are definitely 2 different stands. V8 will bolt to the 250 I6 stands but it places the engine rearward but will work if you are not going for correct. I6 stand on the left, Small block on the right. A big block might bolt to the other stands but factory they used a different stand. Sand blasted pair in the second picture are 1968-71 Big block and the pair with the clam shells are 1972 big block stands and mounts.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. Last edited by Todd68Chevy; 11-19-2018 at 02:54 PM. |
![]() Join Date: Nov 2018
Are you still looking? I have a pair coming out this week from a 72 with a 350
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
![]() Join Date: Apr 2001
I have a set of BB mounts for a '72 but I'm sure the '72 mounts are specific for that year only. Came out of a 2WD. Not sure if there is a difference in 2WD VS 4WD though. They are the same style as the ones in the third picture posted by Todd68Chevy.
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
They are 72 2wd. Can be used in the 68-72. 4wd stands are different and they never offered a big block in a 67-72 4wd from the factory. If your 72 big block stands are for sale then I am interested depending on price and condition. Thanks.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
From my understanding 72 BB is specific to the clamshell style. 1 year big block only, the square bodies went that way. And 2wd vs 4wd is different from 67-91
#9 | |
FWIW, I put a 454 into a '69 K10 and just used the stock SBC (4x4) mounts. Just moved them forward about an 1 1/4" or 1 1/2" to clear distributor if I remember right. Also, moving forward eliminates need to dent rear of valve covers for clearance, IIRC.
Still plays with trucks
Did you ever find the engine mounts you were looking for?
If not I have a spare set of 67-71 small block frame mounts and a set of square body clamshell style frame mounts that I had in my 69 C20 before I converted it to 4wd.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
| Bookmarks |
