Old 09-15-2019, 03:47 AM   #126
ironadict
ironadict's Avatar
Re: Blueballz build thread
First time she was able to drink at the actual gas station instead of me dumping gallon cans in her. Finished tucking wiring away and laid down the carpet. Threw the seat and blanket in temp like till I get the seat foam and cover in. Slightly illegal because I didn’t have seat belts in or even doors or bumpers but she sure is a good driver. Only alignment I’ve done is with a tape measure in my garage and it seems to drive straight as an arrow. Unless I turn the wheels anyway .
HOTROD HOODLUM
ironadict is offline   Reply With Quote
Old 09-15-2019, 01:15 PM   #127
joedoh
joedoh's Avatar
funny how driving like that, everyone gets out of your way!
Old 09-15-2019, 04:28 PM   #128
ironadict
ironadict's Avatar
Yeah they do!
HOTROD HOODLUM
Old 09-15-2019, 06:59 PM   #129
gigamanx
Ha! Looks great! No different than driving a Jeep with the doors off. If they can do it, why can't we?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 09-15-2019, 08:26 PM   #130
ironadict
ironadict's Avatar
Yeah that’s what I figured. I think there’s a law about having some kind of bumper also at least a lap belt. I think it’s supposed to have at least 1 side mirror. I don’t think they woulda given me too hard a time though. Probably just laugh and tell me to drive straight home.
HOTROD HOODLUM
Old 09-15-2019, 08:30 PM   #131
gigamanx
As long as you're going forward, no need for mirrors
Old 09-15-2019, 11:24 PM   #132
59chev
59chev's Avatar
Looking good. Love the stance and the wheel/tire choice!
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 09-17-2019, 01:11 AM   #133
ironadict
ironadict's Avatar
So this just ****ing happened. Trying to put the bolt in the back of the hinge and the damn square washer just fell out of my fender... is there ANY easy way to getting this back in? I’m thinking the only way is pull the tire use a hole saw on the top outer corner of cab so I can put it back in and then weld it up again?
HOTROD HOODLUM
Old 09-17-2019, 10:11 AM   #134
Sal's '55 Chevy
Sal's '55 Chevy's Avatar
im sure you can put it back on from inside the cab no need to pull a holesaw out
'55 Chevy PU 2nd Series
'97 Chevy Silverado XCab
'13 GMC Sierra
Sal's '55 Chevy is offline   Reply With Quote
Old 09-17-2019, 10:18 AM   #135
ironadict
ironadict's Avatar
Only thing I can see inside the cab is maybe someone with really thin arms can reach around the vent blade and put it in there. Unless maybe behind the dash it opens to there. I’ll have to check when I get home. All else fails I’ll just drill a hole big enough for a socket and put a regular nut on there and throw a rubber plug in it so I can get to it later.
HOTROD HOODLUM
Old 09-17-2019, 12:18 PM   #136
joedoh
joedoh's Avatar
I had this happen on a 65 door hinge (captured nut break), thats exactly what I did, drilled a small hole and used a nut.
Old 09-17-2019, 10:53 PM   #137
ndeep
the nut just sits in a braket, you may have to pull fender partialy off to access it though
ndeep is offline   Reply With Quote
Old 09-23-2019, 07:54 AM   #138
ironadict
ironadict's Avatar
Thanks yeah I was under there to pop a hole and I noticed it up there. I didn’t even remember seeing it there when my fenders were off.
HOTROD HOODLUM
Old 09-23-2019, 08:00 AM   #139
ironadict
ironadict's Avatar
Fabbed up a new front bed/step support. Notched for drive shaft. Cleaned up the bed a bit threw it on.
Got it aligned and took it on the freeway before the bed was on and it shook pretty bad from 60-70mph. I’m hopping it just needs the wheels balanced better. Maybe having the bed on will help a little since there’s weight back there now.
HOTROD HOODLUM
Old 09-24-2019, 02:24 PM   #140
slammed57
nice work, where did you get that watts bar set up? looks pretty beefy and stout!
slammed57 is offline   Reply With Quote
Old 09-24-2019, 04:22 PM   #141
ironadict
ironadict's Avatar
Thanks. I got it from thorbros. It usually has all rubber bushings but I custom ordered it with hiem ends instead.
https://*************/4-link-parts/w...-poly-bushings
HOTROD HOODLUM
Old 09-24-2019, 04:25 PM   #142
slammed57
Thanks bud , you truck is coming along nice!!!!
Old 09-24-2019, 04:28 PM   #143
ironadict
ironadict's Avatar
She’s ready for some pipes finally. I’m loosin hearing with those open headers.
HOTROD HOODLUM
Old 09-24-2019, 04:40 PM   #144
ironadict
ironadict's Avatar
Thanks man. Same to you. Awesome sheet metal work! Love your frame.
HOTROD HOODLUM
Old 09-24-2019, 10:04 PM   #145
ironadict
ironadict's Avatar
Pipes in. H pipe no mufflers. Sounds remarkably tame. Unless I really step on it then it’s loud but just cruising around it’s really quite. I am just realizing that one pipe is longer than the other and that’s gonna bug me.
HOTROD HOODLUM
Old 09-25-2019, 09:51 AM   #146
dsraven
yeah, perfectionists always see the little things and it bugs them till thjey're fixed.
do you have a plan for a heat shield and/or thermal insulation on the tank and fuel lines?
dsraven is online now   Reply With Quote
Old 09-25-2019, 10:47 AM   #147
ironadict
ironadict's Avatar
I asked my exhaust guy the same thing. He said as long as there’s an inch between them their fine. What are your thoughts on a safe clearance?
HOTROD HOODLUM
Old 09-25-2019, 11:27 AM   #148
dsraven
my thoughts are:
-use a metal heat shield on the pipes attached with chose clamps or tacked on, leave a small air gap between the pipe and the shield
-use a metal heat shield between the pipes and the tank with reflective material attached to the pipe side of the shield and insulation on the fuel tank side of things
-try to run some of those fuel lines and electrical a different way so they simply don't run past the heat source. possibly straight out the front of the tank and then over to the frame, shielded as req.
-wrap the pipes with header tape to keep some of the heat away from the area
I think you have a heat source right next to the fuel storage/source, fuel pump, fuel lines and some electrical. it will, at least, be heating up your fuel so less molecules per cubic inch for your power ratio (racers try to run the fuel as cool as possible for that reason, right? remember the fuel cool cans with ice) . you could run the fuel and electrical over the tank and out the front side of the tank, between the pipes, and that would help especially with some heat shielding and some retainers for the lines so they don't rub. you could install a reflective heat shield with some non flammable insulation (between the tank and the shield) and that would help. google reflective heat shield for automotive and see what comes up. some eg below. something is better than nothing. I am a professional firefighter so I always see them "after they fail" and the vehicle is reduced to a shell. wouldn't wanna see that happen. so many times guys spend money on the big ticket items but some of the other important stuff gets missed. that would be a shame. even some hot water tank wrap from home depot would work but there are so many great things on the market these days. why go minimal on something that has that much potential to cause problems and delete you investment and hard work. if you look under a modern vehicle there is usually some fairly flexible aluminum heat shielding. maybe a trip to a pick n pull would yield something useful that could be cleaned up and used. I would def reroute the fuel lines and electrical anyway. heat breaks things down and causes premature failure. it also softens things and allows them to take form so things like exhaust hangers will likely have a little more "give" after awhile and could allow some sag in the system. this could mean that inch will become less over time and with use. if a hanger were to fail the pipe could actually be sitting on a fuel line. the other thing to think about is the ride height of the truck. a low truck equals less air under the truck to allow air flow to cool things off when the truck is sitting still or moving slow. what will happen when the truck flexes over a curb or bump etc?
take a look below at some of the links, the youtube one shows some good looking products and there are others in the background that look great too. a bit of that style of product also makes the build look professional and like a lot of thought went into the design.
end of rant, sorry.
https://designengineering.com/produc...ds-reflectors/
https://www.amazon.ca/DEI-010129-Tit...03913138&psc=1
https://www.youtube.com/watch?v=E-hK8r1Ldgg
https://www.heatshieldproducts.com/a...ermal-barriers
Old 09-25-2019, 12:05 PM   #149
ironadict
ironadict's Avatar
It’s more than an inch it looks really close due to the angle. But it was a concern of mine as well when I saw it. Not wanting to wrap everything up. It’s my goal to keep things as clean and simple as possible. I’m just gonna have him tear this out and re do it. He forgot the H pipe and ran one pipe longer than the other and the pipes were supposed to terminate UNDER the back of the fender. I’d rather just have it done right than start bandaiding everything.
my thoughts are:
end of rant, sorry.
HOTROD HOODLUM
Old 09-25-2019, 02:21 PM   #150
dsraven
yeah, take'er back. get what you paid for in the first place.
