Old 09-11-2019, 01:24 PM   #26
_Ogre
_Ogre's Avatar
Re: Let's see your favorite rear fuel tank filler options
Originally Posted by dsraven View Post
hey ogre, did you use the stock spare tire carrier mounts or custom fab a new one.
i run 28" diameter P235/70R15 with 4.5 backspace.
had to modify the spare carrier 3 ways:
1) move spare out 1/2", i had drilled and lightened plate steel
2) drill above plate to handle 5 lug rims
3) shorten top arms to allow for tonneau cover to lap over bed side
not to mention:
4) modify mirror to look past spare
shop air compressor timer
Old 09-11-2019, 05:04 PM   #27
daveshilling
daveshilling's Avatar
Originally Posted by BAM55 View Post
I put mine in the stake pocket of my fleetside.
This is wild, I need to see much more of this!
daveshilling is offline   Reply With Quote
Old 09-11-2019, 05:50 PM   #28
Russell Ashley
Russell Ashley's Avatar
Here's mine. It's a Hagan push-to-open style. I also have the Hagan gas cap that you don't have to remove to put gas in.
Russell Ashley is offline   Reply With Quote
Old 09-12-2019, 12:45 AM   #29
68blackbird
68blackbird's Avatar
1st thread I ever read here was the one for rear gas tank. Saw roger55's post and said that was what going to do...way before I even started working on my truck. Saw several other very cool ideas on this thread. Kel
Kel's 1950 GMC 1/2 ton build
68blackbird is offline   Reply With Quote
Old 09-13-2019, 12:13 AM   #30
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by b-mac View Post
You guys have seen this kit?
This^^ strikes me as the answer a question no one was asking!
It's "trick" - but it's showy for the sake of being showy. Not that that is all bad but if it gets in the way of using your truck the way you want - unloading a bed full of stuff to gas up, then I think it isn't well thought out.
A lot of cool ideas well carried out in this thread. Better than mine, frankly. I like Mark's (Black Sheep) but I don't know how he managed to locate where to drill his board SO exactly?! My Tanks, Inc. "special" tank supposedly made for our TF trucks had the filler come up exactly where one of my bed strips fell. I had to seal it and weld in a new location - ugh!
My personal favorite is still JJ's. His is just a recessed gas cap in a stainless kitchen sink drain escutcheon (I think). It's simple, it saves the wood finish from spilled gas, and just looks clean to me.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is online now   Reply With Quote
Old 09-14-2019, 02:07 PM   #31
mobileortho
mobileortho's Avatar
Jaguar fuel door.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 09-14-2019, 09:14 PM   #32
Dan in Pasadena
^^^ I like the Jag door.
Obviously you had to cut it out of the donor and cut the right size hole in your truck. But other than that, was there a lot of metal work prior to spot welding it in?
Old 09-14-2019, 09:38 PM   #33
mobileortho
Didn’t cut it out from a donor, bought the cap from someone locally but I see them all the time for sale on EBay. I made a cardboard template 1st then the metal. I’m a novice at doing anything like this and thought I’d bitten off more than I could chew but it turned out ok to me!
Robert C.
1950 3600
Old 09-14-2019, 09:58 PM   #34
daveshilling
It looks awesome and if I was painting, I'd rock that. heck I might rock it anyways and just let the bare metal hang out!
Old 09-15-2019, 02:51 PM   #35
_Ogre
_Ogre's Avatar
Jaguar fuel door.
no separate cap? looks good
Old 09-15-2019, 04:25 PM   #36
mobileortho
Thanks Ogre. You can get a cap from any XJ6 I believe up trough ‘86. Here’s one on eBay for $15.
https://rover.ebay.com/rover/0/0/0?m...2F232350728215
I made a cardboard template pretty much like this but it wasn’t too difficult, just had to make sure it flowed with the contour of the fender and was positioned in such a way that it wouldn’t hit the bed roll when it was open. I am by no means a metal fabricator nor have any experience doing anything like this, but with the help of countless videos on welding I was able to make it work. Bondo and body filler are my friends! Lol!
Robert C.
1950 3600
Old 09-16-2019, 12:07 AM   #37
Dan in Pasadena
Thanks, Robert. You did a very good job.
Old 09-16-2019, 10:39 PM   #38
roger55
roger55's Avatar
roger55 is offline   Reply With Quote
Old 09-19-2019, 09:18 PM   #39
mobileortho
Thanks D!
Robert C.
1950 3600
