Old 09-16-2019, 12:43 PM   #1
siggyfreud
siggyfreud's Avatar
Trick for installing park brake cables?
Hey all,
I upgraded my brakes all around, and just got new park brake cables for my rears. Problem is, despite them connecting to the same point on the trailing arms, it feels like the overall cable is about 2" too short to reconnect.
Even after removing the cable from the adjuster rod on the driver's side near the transmission, it's simply too short for me to hook up the brake cable to the driver side disc hat, and still get the cable back into the adjuster rod.
If I put it into the adjuster rod again, then I can't physically get it close enough to the trailing arm bracket to hook it up.
Not sure what the hell to do lol. Anyone run into this?
siggyfreud is offline   Reply With Quote
Old 09-16-2019, 02:37 PM   #2
sfcharr
Re: Trick for installing park brake cables?
I had the same problem, solved it by adding a 3" piece of threaded rod and a threaded coupling to give me additional length for adjustment. That was my fix, anyone else have to deal with this?
sfcharr is offline   Reply With Quote
Old 09-16-2019, 04:02 PM   #3
HO455
HO455's Avatar
Is the hook on the front passenger side in the correct hole? I am assuming the rear cables are the same length as the old ones.
RIP Bob Parks.
