![]() Join Date: Apr 2016
how to stop loosening of a head band
Is there something like the opposite of WD-40, that is a spray with nozzle and will cause friction instead of removing it? Other ideas? I have this light and magnifier headlight I like to use, but the knob I turn to tighten it does not hold its place well. It is like the knob in the headband of a hard hat, turn clockwise to tighten the band, counterclockwise to loosen, and it has click stops but they are very weak. When wearing, the tension of the plastic band is enough to make it pop loose while wearing.
Re: how to stop loosening of a head band
1. dont think so hard...brain wont swell.
2. look for a similar head band from a welding hood, they have a strap over the top as well, and allows the head strap to be a slight bit looser. |
Thanks. Well I suppose I'll see if I have any luck gluing it in my favorite size. I don't have an old welding hood with good band to cannibalize in order to fix this $15 magnifier.
Maybe a pop rivet, then it could be undone......oops post is 2 months old that ship has probably sailed...
No, I haven't glued it yet. I like the idea of pop rivet. I don't have a pop rivet tool, but you have me thinking. I can drill and screw it, use a small flat head machine screw in a countersunk hole on the inside and wing nut on outside. It would be removable, or repositionable into a different hole for 2 different sizes, one for when I need a haircut, and one for when I just got a haircut. Thanks.
![]() ![]() Join Date: May 2015
have you tries wrapping a rubber band around behind the knob?...here
I have not thought of that. Thanks for that idea. I will give it a try.
![]() Join Date: Jan 2001
In the hardware section of Lowes or Home Depot they have screws that have a low-profile head that are meant for putting furniture together. You might put one of those on the inside of the band with a wingnut on the outside. That would make it easy to adjust.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#9 | |
![]() Join Date: Jul 2015
I do like the rubber band idea, 2nd the pop rivet for a permanent thing also. |
Tags |
friction, headband |
