#26 |
![]() Join Date: May 2013
Re: V8 tach dash with clock
PM sent.
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
#27 |
sweet dash job!!! not bad pricing either!
Ben Smith |
#28 |
I would like one like this but with an 8k tach and a good used bezel for my 68. don't want a bezel that looks new. my truck is also an ex 6 cyl truck with an idiot light dash and currently a 350 and hei...
Trey
68 Short step!! |
#29 |
![]() Join Date: Apr 2010
Trey, the 8k tach/clock dash would cost you $550 shipped and you will have to change your wiring harness out to make it work correctly! LMK, thanks for your interest Les
#30 |
I can say one thing-----the tach dash I bought is sweet. Works perfect and looks awesome.
I had an idiot light dash and rewired it in an afternoon with the instructions on GMC Paul's website.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#31 |
Also, a note to anybody swapping in gauges. If your temp gauge stays pegged hot, add a ground wire to the back of the gauge and connect to the body. Took me 2 weeks of searching to find that solution.
#32 |
Thanks for the information on the wiring from idiot lights to gauge package wiring harness, Les
#33 |
Out of curiosity, where did you buy your clocks?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#34 |
#35 |
Still plays with trucks
Very nice work.
Have you looked into an electronic speedometer retrofit that uses the stock truck gauge face? A little less money than an external speedo Cable-X like drive box when using an electronic trans without a mechanical cable speedo output. Re-screen gauge face for 120-mph and stencil lens numbering to match or re-calibrate electronic speedo to read right for the 100 mph markings on our stock speedo.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#36 | |
