Old 09-23-2019, 07:35 PM   #1
Afirehawk1
66 C10 Holley 750 Throttle Cable Connection
I have a Holley 750 while using 67/72 throttle cable and pedal.
Looking how to finish the connection between the 2
Photo attached
Afirehawk1 is offline   Reply With Quote
Old 09-23-2019, 08:19 PM   #2
geezer#99
geezer#99's Avatar
Re: 66 C10 Holley 750 Throttle Cable Connection
Use this.
https://www.holley.com/products/fuel...ge/parts/20-14
Old 09-24-2019, 01:46 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Connect it with an e clip to that post that has a groove in it is how I connected mine. I'm using a squarebody pedal, but same general idea and cable type
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-24-2019, 03:05 PM   #4
geezer#99
geezer#99's Avatar
That post with the groove is part of the kick down lever on his Holley.
It moves independently from the throttle lever.
Old 09-25-2019, 12:12 AM   #5
cwcarpenter98
Ah, did not know that. In that case, completely ignore everything I said Sorry about that, I've never worked with a Holley before
Christian Carpenter
Old 09-25-2019, 06:00 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
here is mine. I used original linkage.
DPowers is offline   Reply With Quote
Old 09-27-2019, 07:34 PM   #7
bama63
bama63's Avatar
i used these https://www.speedwaymotors.com/Speed...hings,613.html and a 1/4 inch bolt and lock nut hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 09-29-2019, 06:51 PM   #8
Afirehawk1
Ok
Got the bracket
Fits great
What should i use to connect the cable to the bracket so it pivots correctly without binding?
Old 09-29-2019, 09:48 PM   #9
geezer#99
geezer#99's Avatar
Likely like bama did with a bolt and jam nut.
