Old 09-24-2019, 05:41 PM   #1
cgster
Removing/Installing Door Window
The passenger side window on my 68 C10 was shattered so I have the replacement glass to replace it with. What all do I need to remove in the door to install the new glass? Just trying to take out the least amount of door items that I can. Thanks.
cgster is offline   Reply With Quote
Old 09-24-2019, 06:39 PM   #2
rockyrivermark
Re: Removing/Installing Door Window
There is a great write up on here with step by step instructions.
I used it to pull all my glass and vents to paint.
Do a forum search and I’m sure it will come up.
Mark
rockyrivermark is offline   Reply With Quote
Old 09-24-2019, 06:46 PM   #3
Thegoose74
https://youtu.be/Zay64xBOgD8
Here is a good video
He has one on disassembly as well
Thegoose74 is offline   Reply With Quote
Old 09-24-2019, 06:47 PM   #4
NorCalC20LWB
Here are two good sets of instructions, worked well for me....
http://67-72chevytrucks.com/vboard/s...g+window+felts
http://67-72chevytrucks.com/vboard/s...d.php?t=779572
NorCalC20LWB is offline   Reply With Quote
Old 09-24-2019, 08:01 PM   #5
Lanman1972
Lanman1972's Avatar
Look up this thread: Door Assembly...the EASY way, by Randy500
All the info you will need. Goodluck!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 09-24-2019, 09:39 PM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I unscrewed the Phillips head screws that hold the rail in the rearward part of the door. This allowed the window to be pushed rearward on the regulator to get the rollers to the opening on the bottom of the window to disconnect the window from the regulator.
I'm going off of memory from a year ago... but a week after I installed the glass in one door, I forgot the sequence and screwed around on the second door.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 09-24-2019, 10:27 PM   #7
randy500
Click the link to door assembly in my signature line.....
randy500 is offline   Reply With Quote
Old 09-25-2019, 01:02 AM   #8
MySons68C20
MySons68C20's Avatar
randy500's tutorial worked for me. Thanks again!!
MySons68C20 is offline   Reply With Quote
