08-26-2019, 06:25 PM | #676 |
Re: 67 GMC super custom build
I believe 283 was red like the inline 6's were ( at least in Canada) and 327 was orange. I had a 67 gmc with a 283 and it was red. This is the original 327 from another 67 I have and it is orange. It looks pretty original.
09-25-2019, 12:53 PM | #677 |
Fog lights are in the bumper. They are fully adjustable up-Down and left-right. Might have to make a slight modification to the outer bumper brackets.
09-25-2019, 01:01 PM | #678 |
Now that is cool! Good stuff
09-25-2019, 02:15 PM | #679 |
I'm trying....
That is super slick.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-29-2019, 08:12 AM | #680 |
09-29-2019, 08:20 AM | #681 |
They are from a 1957 Cadillac
09-29-2019, 07:51 PM | #682 |
Those look really good Rod, (and like factory). Bang-on with my mocked-up photo in post 652.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
10-11-2019, 05:38 PM | #683 |
I put my headlight relays into a external regulator housing. I wanted better lighting but didn't want to pur modern relays into my engine bay. They would look out of place. Now I just need to change the lighting harness to work with this. I saw another member do this and thought it was clean looking.
10-11-2019, 05:39 PM | #684 |
Few more
10-11-2019, 06:26 PM | #685 |
Slick!
10-16-2019, 11:40 AM | #686 |
I got some led fog lights for my truck and made a relay for them as well. I had to add the ring to the base of the led lights as the originals mounted different than most bulbs of the era. I won't throw out the originals though. I also ordered led headlights that have a glass pattern like the originals and got robznob11's led bulbs for everywhere else. It can still look original with modern lighting! https://www.ebay.com/itm/5-3-4-Stock...53.m1438.l2649
10-16-2019, 11:42 AM | #687 |
That's pretty damn cool man. Good stuff!
10-17-2019, 10:58 AM | #688 |
Nice lighting! Where did you get the headlights?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-17-2019, 11:09 AM | #689 |
I got the headlights from octane lighting. They fit the headlight buckets with no cutting which I liked as well.
10-17-2019, 04:58 PM | #690 |
Starting to get ready to fire it up and making sure all the brackets fit as they should. It's amazing how crude gm made the ac brackets in these years. Guess it was just for a work truck back then. I'm going to mount the instant aire vacuum port to the ac bracket on the top corner. It's close to where Pontiac put it on their engines.
10-22-2019, 04:00 PM | #691 |
I had to redo the oil pan as everyone says to put dabs of rtv in the corners to the block with it so I did. Hope this is the last time it's upside down and hope it doesn't leak. Now I can finish the top side!
10-22-2019, 04:26 PM | #692 |
Looks pretty nice! So shiny
10-22-2019, 05:22 PM | #693 |
These are my goodies for this engine to make it period correct. I have doubles of most. Going to put the block heater in this afternoon. The one cord is original from my 67 and the other is Nos. The angle of the plug to the heater is different and the Nos is about a foot longer and has a ground on it.
11-02-2019, 08:50 PM | #694 |
Making sure all the brackets line up and so far so good. Not going to mount the ac compressor till its in the truck. Now to take the accessories off and get it in the frame and start it!
11-02-2019, 09:17 PM | #695 |
I'm trying....
So fresh and so clean.
11-02-2019, 09:36 PM | #696 |
11-02-2019, 10:06 PM | #697 |
I'm trying....
She's been winning some battles. Hopefully more progress in the coming days...loving what you're cooking though. Thanks for the pics!
01-14-2020, 09:50 PM | #698 |
So I have been fighting my distributor for. The last while. It won't sit down clean to the intake. It sits 1/8" or 0.010 high and bottoms out. Heads were shaved, block was not decked. All gm parts here and were checked by professionals before I assembled it. I've tried everything so I guess the pans gotta come back off and take a look at the oil pump-shaft connection. Thats all that's left. Good thing I haven't put oil in it yet. I have tried a few hei dizzy and they all sit exactly the same.
01-14-2020, 10:46 PM | #699 |
That’s frustrating, hope you can figure it out
71 C10 72 K20 72 K10 Super Kirk |
01-14-2020, 11:33 PM | #700 |
How thick is the distributor gasket? I measured one and it seems to be about .054" thick.
