Old 09-26-2019, 04:02 PM   #1526
Sloonz
Re: Whose on Steelies? Post 'em up!
Originally Posted by billneumiller View Post
Took some new photos last fall.
Beautiful truck and great stance. What drop and what size wheels/tires?
Sloonz is offline   Reply With Quote
Old 09-26-2019, 06:56 PM   #1527
paul blair
Originally Posted by 3757chevy View Post
OK ... So I gave up on that idea, I picked up a set of really nice caps and have broken down and bought 15x8 and 15x10 series 62 Wheel Vintiques.
PRIMO SETUP...Best look for these trucks...up graded and stock at the same time...good choice!
paul blair is offline   Reply With Quote
Old 09-27-2019, 12:11 AM   #1528
PepperTreeGarage
PepperTreeGarage's Avatar
Originally Posted by Sloonz View Post
What drop do you have on your truck? Looks similar to mine but I have 15x8 rally wheels. Mine is 3/5 but I was planning on going down to 5/7 and am wondering if it will rub.
The Drop is 5.5 in the front. 2.5" drop spindles and 3" drop coils. Front rubs a little at full turn. We've since went with a 2" drop spring. The rear is a FlipKit with one leaf pulled and helper airbags installed for hauling and trailering duties. So it's about a 6 or 7 inch drop in the back.
PepperTreeGarage is offline   Reply With Quote
Old 09-27-2019, 12:15 AM   #1529
3757chevy
3757chevy's Avatar
Thanks, I'll try to get installed pics once I get the truck back on the road.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is online now   Reply With Quote
Old 09-28-2019, 04:53 PM   #1530
FabricatorKevin
FabricatorKevin's Avatar
My .69 C20 with new 16" x 8" steel wheels
FabricatorKevin is offline   Reply With Quote
Old 09-28-2019, 11:02 PM   #1531
sixtyeightC10
Still running on factory wheels and hubcaps. Couldn't see myself dumping them.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades.
Formerly known as mtndewmaniac66.
sixtyeightC10 is offline   Reply With Quote
Old 09-28-2019, 11:29 PM   #1532
Hotcorner
Hotcorner's Avatar
16s with caps
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 09-29-2019, 01:32 PM   #1533
solospeedshop
solospeedshop's Avatar
Just bought this from original owner it has Chrome Reverse he put on truck from dealership before he took truck home! He bought 5 one for spare! I didn't even know they made them and they took original caps he got the truck in Sept 71! Tks Bill
solospeedshop is offline   Reply With Quote
Old 09-29-2019, 02:04 PM   #1534
davischevy
davischevy's Avatar
Here is a double take. My son in laws K10 hauling my Longhorn home.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-29-2019, 02:20 PM   #1535
davischevy
davischevy's Avatar
Originally Posted by DeadheadNM View Post
Recent pic with my fresh springs and shocks. OEM 16.5" steelies
Pete, what brand spring did you use, and are they stock arch? Do you have any other lift on the truck?
Thanks,
other Larry
other Larry
Old 09-29-2019, 04:30 PM   #1536
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks,
other Larry
Hi Larry - love your pic btw, too cool. Springs came from Alcan Spring in Colorado. Zero lift stock height built to order w USA steel. No body lift. The 33" tires bump it up a bit. I'm happy with the stance as I can scramble in/out pretty easily.
Old 09-29-2019, 04:48 PM   #1537
davischevy
davischevy's Avatar
Obviously I like the stance on your truck too (along with everything else about it).
You may not remember, but, this is the truck I was going to get when I contacted you in Albuquerque. My plans changed in California and it was early morning when I came back through so I didn't bother you. Anyway, I have it apart now and I may as well put in new springs. It looks like it sits a little low in the front.
http://67-72chevytrucks.com/vboard/s...d.php?t=755797
other Larry
Old 09-29-2019, 04:56 PM   #1538
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! Thanks for the link. I'm on board.
I re-arched the OEM springs on the K20. What a waste of time/money. The ride quality was substantially improved with new springs. I also replaced the plastic liners/anti-squeak spring pack pads with the new springs.
One of the major truck vendors sells small asphalt pads for use between the bed to frame mounts. I used those at the time of the build. Maybe it quiets the ride a little bit. Maybe not. These didn't alter the body lines at least.
Old 09-29-2019, 09:44 PM   #1539
VWNate1
VWNate1's Avatar
Post Leaf Springs
' re - arching ' leaf springs is an old time scam ~ they ride higher again for a short while then poop out again, money wasted .
The teflon spring sheets really work wonders at making the rig ride smoother while still retaining the height and load capacity .
Beware cheapo springs ! .
Diamond or Eaton are both very good and there used to be plenty of other American spring manufactures .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 09-30-2019, 10:47 PM   #1540
3757chevy
3757chevy's Avatar
...not quite road ready ,but rolling again.
MIKE
Old 10-25-2019, 12:04 AM   #1541
3757chevy
3757chevy's Avatar
...all back together again.
MIKE
Old 10-25-2019, 09:37 AM   #1542
VWNate1
VWNate1's Avatar
Thumbs up On The Road Again
Good deal, looking nice .
-Nate
Geezer
Old 12-06-2019, 03:07 PM   #1543
67_C-30
I have a radical idea!
67_C-30's Avatar
Way better!!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-06-2019, 04:41 PM   #1544
3757chevy
3757chevy's Avatar
Originally Posted by 67_C-30 View Post
Way better!!!
...... I have had a lot of thumbs up recently.
MIKE
Old 12-06-2019, 06:39 PM   #1545
Chevys4life
1970 C20 with 16X7 steel rims.
Chevys4life is offline   Reply With Quote
Old 12-06-2019, 08:04 PM   #1546
weim55
Looking at Ford 16 x 7s for my 69, Is that what yours came off of?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 12-07-2019, 11:37 AM   #1547
jsprengeler
jsprengeler's Avatar
Looks great! Like the black paint, don’t see many of those.
Incapable of not thinking about my truck at least every other minute
jsprengeler is offline   Reply With Quote
Old 12-07-2019, 11:48 AM   #1548
Chevys4life
Yes...........those are the Ford rims.
Old 12-07-2019, 11:49 AM   #1549
Chevys4life
Thanks.........the boy is coming into it's own identity now.
Old 02-01-2020, 10:18 PM   #1550
STPETEBLUE
STPETEBLUE's Avatar
Here are my steelies.
Daily Driver:
2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed
Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded).
STPETEBLUE is offline   Reply With Quote
