#26 |
![]() Join Date: Aug 2004
Re: LED Headlight Conversion
How about just putting relays and pull the power off the battery and not through the switch?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#27 | |
#28 |
![]() Join Date: Jul 2014
I sure wish they would outlaw Led lights , I know they the new thing but man when you are driving the other way they hurt... If your are in your work car at 4:00 am in the rain. The new Ford trucks are BAD Wow!
Maybe I am old? |
#29 |
https://www.theretrofitsource.com/mo...dlights-7.html
Check these out for a budget friendly LED swap. They are what I run and they easily keep up with the $600 sets for $150. Highly discounted due to being an old generation of them. Posted via Mobile Device |
#30 | |
#31 | |
I didn’t check to see if there were chrome left, not sure how the black would look. I have them on mine with no anti flicker and they’re just fine. I don’t see a need for the anti flicker harness. Posted via Mobile Device |
#32 | |
60-66 Nut
It sounds to me like what you really need is an alternator upgrade and a relay setup for your headlights.
#33 |
meowMEOWmeowMEOW
Not sure if it matters to most, but the Morimotos' aren't DOT.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#34 |
The Morimoto's are stamped DOT SAE, so I believe they are DOT legal.
#35 |
meowMEOWmeowMEOW
I only mentioned it because I didn't see anything about DOT on the spec page, nor could I see it on the lenses in the picture. If yours actually have that stamped, then they probably are.
#36 | |
#37 | |
Never Ending Projects
Look at J.W. Speaker's site, DOT info is all over it, http://www.jwspeaker.com/products/le...8700-evo-2-db/
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#38 | |
#39 |
Well I went with the MORIMOTO's. I'm not sure when they will get here but looking forward to trying them out. Do you guys use the DRL feature or just leave it unhooked?
#40 |
Chevy addict
Good battery, 105 amp alternator and a United Pacific relay set up with halogen headlights work great and brite
#41 | |
I’m going to order these tomorrow once I know how to install them. ![]() |
#42 |
#43 |
What type of lights are these
#44 |
Anyone know if the cibie h4’s fit in buckets without modifications?
Thx |
#45 |
#46 |
They do. Purchased Cibie H4's for my 65. Fit perfect. No mods.
#47 | |
Are you guys simply trimming the bucket for fitment? Also, anyone have a recommendation for the hookup point for the tan wire, which I assume is either a DRL or turn signal feature? |
#48 |
UPDATE:
I cut the factory buckets to let the Morimotos sit down far enough to screw down the retaining ring. Glad I have spares. ![]() |
