Old 09-27-2019, 09:12 PM   #26
BigBird05
Re: '71 GMC 2500 exhaust manifold (350) interchange.
The only time I have seen a manifold turn cherry red was when it was run on a Dino at WOT and maximum load. That kind of sustained heat will do that to cast iron.
BigBird05 is offline   Reply With Quote
Old 09-28-2019, 12:00 AM   #27
W. Higgins
W. Higgins's Avatar
On earlier vehicles where you manually control the spark advance having the spark severely retarded will do it too, but in this case I haven't had the timing slip and when you run that heavily retarded you'll eventually see the coolant temp rise, which also hasn't ever been an issue.
W. Higgins is offline   Reply With Quote
Old 09-29-2019, 08:59 PM   #28
W. Higgins
W. Higgins's Avatar
I swapped out the manifolds last night and had it running before bed. Took it out for a drive after tidying up some things this morning and it's still the same great running truck it always has been. While the manifolds were off I pulled the plugs and did a quick compression check. Everything is about 150lbs+. Timing is exactly where it's supposed to be and nothing is amiss. Thanks to everyone for helping me quickly resolve the part application issue so I could get this out of the way before the week started.
Old 09-29-2019, 09:19 PM   #29
AussieinNC
Moderator
AussieinNC's Avatar
Many thanks for the update!
The folk here love to help everyone out...
Enjoy your truck !
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-29-2019, 09:34 PM   #30
W. Higgins
W. Higgins's Avatar
I know how people like to see these old beasts still in service. This was back in the spring dragging home a new piece of iron.
Old 09-30-2019, 09:35 AM   #31
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: '71 GMC 2500 exhaust manifold (350) interchange.
Glad you got it going again. Those manifolds will blow out like that if you hit them with water after a long hard run. Are you open the hood up after a long run in the rain the rain runs off the hood down into the motor. Over time they get weak and will blow out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
