Old 06-08-2004, 01:36 AM   #1
1972C10
1972C10's Avatar
85 ScottsDale 20 Rear Brake Prop Valve ??
Does Anyone Else have This? Or is it an option on a heavy duty jb6 brake system I think thats the number my brake system is the best one WIth the cast Iron master Cylinder And One Ton Rear Shoes
1972C10 is offline   Reply With Quote
Old 06-08-2004, 01:37 AM   #2
1972C10
1972C10's Avatar
O yeah i think this valve give it more or less rear brake the more its loaded
Old 06-09-2004, 01:58 AM   #3
apstguy
LED King
apstguy's Avatar
Correct. They commonly go bad too so if you have brake problems, bypass it. They never worked that well anyways.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 06-09-2004, 09:57 AM   #4
Grim Reaper
My 88 3/4 ton burb has one. Seem to function on my 88. You correct, it put a little more brake to the rear as load causes the rear to drop.
When I have my Cargo trailer and a load in the burb I do notice a change in the brakes. I had a brake pull from a stuck adjuster in the rear that became VERY apparent with load but hardly noticed it empty.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 06-09-2004, 08:18 PM   #5
1972C10
1972C10's Avatar
Yeah my rear shoes are super thick and i just put new carbon metalic and rotors on the front it stops good the pedal just goes down more than i think it should
Did you bypass yours? It has a prop valve up front too Im just wondering why it has this and what if the other prop valve puts 100% to the back and this second one is supposed to do the rest.
