![]() Join Date: Jan 2011
Re: 71 C10 Brake Master Cylinder / Booster Questions
I would post a wanted ad in the 67 to 72 parts section for the booster parts. The master cylinders are different because one is for drums and the new one looks like a disc application.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#2 | |
I'll keep the new one as I have front disc brakes. Thanks for the help.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
#3 | |
Manual brake master cylinders typically have smaller bores which yield greater line pressure since there's no additional leverage. Power brake master cylinders have different bores to allow tuning the pedal travel/feel when braking. Sometimes it takes some sorting to get what you like.
#4 | |
