87 tbi header options?
I am looking to add headers to an 87 r10. What are my options to clear the frame? I know I may need to add the o2 bung.
Re: 87 tbi header options?
A TBI engine is no different than any other small block. Any headers designed for a squarebody with a SBC will fit your truck.
Brief research indicates you may also have to switch to a heated o2 sensor.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
^^ What he said ^^
Any standard replacement header for your year model range & a properly placed heated o2 sensor (the heated o2 sensor works better vs the stock non-heated).
I have a set of Doug thorley tri Ys on my 87. Been on there 15 years and held up great
| Bookmarks |
