Old 06-09-2004, 07:09 PM   #1
buckola
1 Wrench / 10 Knuckles
buckola's Avatar
&*#$F%% dipstick
I'm 3-5 hours away from completing my vortec upgrade when the dipstick shaft breaks of in the block . I've tried everything to remove it. heat, pry bar, pliers vice grips...even tried holding a piece of cheese in front of it. Looks like I'll have to pull the engine like I should have in the first place. Up side is I can replace pan gasket and seals
1970 GMC Custom
Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers
2006 Dodge Charger SRT8. 1/4 mile 13.3
1973 Z1 900 Kawasaki ( all original)
buckola is offline   Reply With Quote
Old 06-09-2004, 07:43 PM   #2
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Tough break man! It's always the little things isn't it..
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 06-09-2004, 07:47 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I was able to stick a large straight blade screwdriver in mine, and twist it a little to break it loose. It came right out. But the odds of that happening for you are probably between slim and none. I just got lucky.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-09-2004, 07:55 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
try this. takes 2 guys.
thread a 5/16 tap into tube, clamp vise grip on top of tap, have buddy hold vise grip straight out while you go underneath with a straight prybar & small hammer. hold prybar against visegrip & tap on end of bar. works about 50% of the time but worth a try.
just did the same thing on a olds powered front wheel drive motorhome today.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-09-2004, 07:56 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used a little flat blade screw driver to push the tude together just enough so that I could use a pair of needle nose plier's to pull it out..
FRENCHBLUE72 is offline   Reply With Quote
Old 06-09-2004, 08:14 PM   #6
1972C10
1972C10's Avatar
I have used Lag Bolts Like for wood and screwed them in a ways and pryed them out.
1972C10 is offline   Reply With Quote
Old 06-09-2004, 10:43 PM   #7
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
A slide hammer (dent puller) will do the job too.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 06-10-2004, 12:18 AM   #8
chevymad
I've screwed some allthread into it, then dropped on a spacer and nut. Tightened the nut and pulled it right out.
chevymad is offline   Reply With Quote
Old 06-10-2004, 10:13 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I put up with a broken dipstick tube on mine for years! Then one day, I decided to remove that broken piece for once and for all so I used a large EZout extractor. Worked like a charm!
Life's never been sweater since.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-10-2004, 11:01 AM   #10
buckola
buckola's Avatar
Gee.. I thot I was the only pathetic loser to have that happen to them
I wasn't expecting all these tips and suggestions ! You have inspired me to continue the good fight
thanks heaps guys
steve
1970 GMC Custom
Old 06-10-2004, 11:20 AM   #11
jimfulco
Did you lose the stick or did the tube break off? If it's just the tube, thread a bolt into it & use a small open end wrench & a hammer to tap upward on the bolt. If it's the stick, I'm of no help whatsoever.
jimfulco is offline   Reply With Quote
Old 06-10-2004, 12:06 PM   #12
buckola
buckola's Avatar
The tube broke off at the block...the stick is safe and sound. I'll have to use a tapered punch and try to open up the tube end cuz i mangled it pretty bad using vise grips, chisels etc. Once I get the tube "some what" round all attempt all the suggestions.
thanks
1970 GMC Custom
Old 06-10-2004, 08:02 PM   #13
buckola
buckola's Avatar
Well...I tried most of the suggstions but to no avail. i'll swipe the easy outs from work tomorrow and give that a try. If this fails, what do you think the chances are of dropping the pan or at least moving it out of the way enuff to drive out the tube from the bottom with a brass drift. Does it sound crazy enuff that it might work?
1970 GMC Custom
Old 06-11-2004, 04:50 AM   #14
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I'll bet you could just dive it into the pan.Then lower the pan enough to fish it out with your fingers.
Just a suggestion.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-11-2004, 12:15 PM   #15
buckola
buckola's Avatar
If the easy outs don't work, thats the next plan Bobby
1970 GMC Custom
