Old 10-03-2019, 09:33 PM   #1
cfan10
cfan10's Avatar
Cool Wheel spacers to convert 5x120.7 to 5x127
I don't have much knowledge of these things, bolt patterns, backspacing and offset etc.
As always thanks in advance for your time!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 10-04-2019, 07:44 AM   #2
sweetk30
sweetk30's Avatar
Re: Wheel spacers to convert 5x120.7 to 5x127
whats the end goal ? ?
more info would help .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-04-2019, 02:38 PM   #3
Loco83
Loco83's Avatar
Stay away from spacers.
Loco83 is online now   Reply With Quote
Old 10-04-2019, 04:24 PM   #4
sweetk30
sweetk30's Avatar
i ran a set of 3" ebay spacers for 10 years on a 8 lug flatbed dump plow truck it was a c&c narrow rear i wanted to single out over the duel rims . not one problem .
i always use a dab of blue locktight and got 10ft-lb more on torque spec for the spacers to the vehicle so there a bit tighter than the wheel to spacer if a set of nuts was to loosen up .
Old 10-04-2019, 04:48 PM   #5
SCOTI
SCOTI's Avatar
Spacers that go between the existing lug/mounting surface & the wheel mounting pad by simply slipping over the lug studs should be no more than 1/4" thick to be safe.
The 'spacers' in the OP's opening post are adapters. They are fine since they utilize the original studs to seat & secure them. New studs in the adapter are used to seat the actual wheel. Basically the same as an aluminum wheel w/an extra thick mounting pad or a vehicle w/a wider track width.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-28-2021, 01:15 PM   #6
cfan10
cfan10's Avatar
Trying to use s10 iroc style wheels on my c10. Thanks for all the info!
Old 01-28-2021, 01:31 PM   #7
b454rat
I have adaptor/spacers like that on my Tahoe. Running C5 vette wheels. Not one issue, had it up to 100 n wheels didn’t fall off.
Old 01-29-2021, 08:59 PM   #8
cfan10
cfan10's Avatar
Cool Re: Wheel spacers to convert 5x120.7 to 5x127
Those wheels look awesome on the Tahoe!
Old 01-29-2021, 09:13 PM   #9
joedoh
joedoh's Avatar
i use those bolt on adapters a lot. no problems. I like to use ET (extended thread) lug nuts on the adapter to hub side, for extra threads on the stock studs.
remember you are adding 1.25" thickness, so you are taking away backspace. a wheel with 5" backspace will only have 3.75" backspace if you use those.
looks like you got the right spacer to go 5x5 to 5x4.75
Old 01-29-2021, 10:48 PM   #10
layinrocker65
layinrocker65's Avatar
People who tell you to stay away from spacers(adapters), have never used them. Thousands of people use them without problems.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 01-31-2021, 08:37 AM   #11
b454rat
Cfan10 thanks!!! They are dirt cheap. I picked a set up that were virtually mint for 180 bucks. Bought 2 fronts (they are staggered, 17s up front 18s rear) for $50.
In order to run a 10" wheel in the back, I'd need a 5.25" b/s I think it was. I have a 2.25" in the back, and the wheels have a 7" something. If I would go any lower, they would rub on the outside, they need to come in lil more. I don't want to go any lower, but would love to go wider, but when I ordered a 315/40, it was HUGE, bigger than what the specs said it was. Plus would need a wider rim, and once go over a 9.5" wheel, they get expensive...
I have 2" spacers on my lifted Tundra with 35" tires and 20" wheels. I've had it over 100mph, never an issue. Been on for 6-7 years I think now. Both sets of adaptors and/or spacers I bought off evilbay, bout $100 a set.
