#126 |
Re: HP Tuners Tutorials
I looked at all those dudes videos and then some more. I liked this gentleman as well, very well spoken.
https://www.youtube.com/watch?v=cX0OuvgUCbQ |
#127 | |
![]() Join Date: Aug 2014
#128 | |
If you swap a good plug and its plug wire to another cylinder will it fire there? Will the bad plug / wire fire in the before working cylinder, on that coil? A lot of times guys blame grounds, each side of coils has its own ground and the PCM uses four on these PINS: 1 and 40 on each of the blue and red connectors Check out the link here: Grounds Demystified Did you thin out your own harness did you repin any wires? sorry if asked and answered which 3 cylinders fire? what do they have in common? are they all Odd or all Even for example, since the PCM has an Odd coil and an Even side coil what codes show up in the Scan Tool? did you check your fuses? even if they look good to the eye just replace the ones for the Injectors and Coils for funzies Last edited by Gregski; 10-07-2019 at 09:53 PM. |
#129 | |
It's firing on 1,7 and 8. Since we knew those three were firing, we did a rotation of all of the coils and wires to verify those were good as well. And they were. We had a ground problem at the beginning, as it seems not having a ground hooked up will cause problems lol. I didn't have the ground hooked up for the coils. it is now. Yes the harness is thinned out, but we didn't repin any of the inputs/outputs on the PCM. I didn't see anything that popped out on the scan tool, but I shall double check it. And yes sir, VATS is disabled. could it be an airflow/fuel/spark Oh and fuel is constant 58-60 psi with cranking |
#130 | |
LOL, what else is there, ha ha - as an old timer once told me, unless you're trying to start a vehicle under water don't worry about the air, ha ha, focus on the other two, fuel and spark
Scenario 1. you take a good coil/wire/spark from cylinder #1 and put it on bad cylinder #2, what happens there? does two fire or not? Scenario 2. you take a bad coil/wire/spark from cylinder #2 and put it on good cylinder #1, what happens there? does one fire or not? share a pic of your fuse block or a link to your build please (sorry I don't show sigs on my forum view in case you have it in there) what is it out of Year / Make / Model / Mods I think you said heads, so I am assuming whole enchilada, did you swap injectors, did you decap them? if you built your own fuse block did some of our connections come loose? Last edited by Gregski; 10-07-2019 at 11:11 PM. |
#131 |
Re: HP Tuners Tutorials - Section F Disable the Catalyst System Codes
HP Tuners Section F Disable the Catalyst System Codes
In this article we disable what we hope will be the last of the codes. It is common for LS Swappers to run exhaust systems less the catalytic converter so it makes sense to suppress any diagnostic codes which may surface do to it's absence. There will be an accompanying write up on how to actually turn off the catalyst PCM controls but for now we focus on just the codes. On my 2001 Siera donor PCM there were two Catalyst System codes, your PCM may be a little bit different: P0420 Catalyst System Efficiency Below Threshold (Bank 1)[Just Sayin'] There has never been a more suitable code than a 420 for dealing with lighting up and smoking something, and they say GM egineers have no sense of humor [/Just Sayin'] Now let's look at the Black Magic that it takes to disable these codes, we have two controls:
1. We fire up our laptop and launch the Editor. Open the file we saved in Section F. (Our last saved file is always our starting point). 2. Make changes in the Editor, this time we will make changes only to the Catalyst System codes under Engine Diag \ DTCs. Refer to the cheat sheet below and Disable the SES on these and set the MIL to No Error Reported, some may be disabled already by default: P04203. Save the changes you made to a new file and call it something like "11 - Disabled Catalyst System Codes" 4. In your vehicle hook up your HP Tuner to the OBDII port and then your USB cable to your laptop, turn the key to the ON position, launch the Editor program, and simply write the new changes to the PCM. Note: sometimes you have to write the entire tune file to the PCM, sometimes it is perfectly happy with only writing what's changed, more on this later. More words with each pic: Last edited by Gregski; 11-08-2019 at 03:32 PM. |
#132 |
junkyards cut these out in California so I can only assume this is what they look like, ha ha
#133 |
we open up the VCM Editor because that's where we will be making our changes
#134 |
two catalytic converter codes get turned off, P0420 (hee hee) and P0430
#135 |
be descriptive when you name your file, a sentence here is better than an abbreviated word, six months from now you will thank me for nagging you to do so
#136 |
Write Calibration aka Flash your PCM
#137 |
![]() Join Date: Aug 2018
Gregski - as I said before, awesome writeup. You've broken down what appears to be rocket surgery and made it understandable. Just wanted to let you know that we do read this and appreciate the info very much. Keep it coming please!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#138 | |
Anyone else following along, please don't be a stranger, I don't mean to ever sound like a know it all, so just chime in correct me where appropriate, ask questions if something is not clear, and call my B.S. when you think I am pouring it on a bit too thick, ha ha. |
#139 |
![]() Join Date: Jan 2011
I have an LS swap in my future and have been following along as you ad content. I like the format as it makes it easy to do for one but having it broken down into sections allows for an easier search if you have a specific topic you need to get figured out. Keep it coming!
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#140 |
![]() Join Date: Aug 2004
Keep em coming! I’ll be doing the tuning on my LQ4 eventually, hopefully next spring or summer.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#141 |
For those of you following along in the LS Swap planning stages, you can download the HP Tuners software for free from their website, it is legit not pirated and you can start practicing and following along what I am doing, you can read the tune files, you can make changes to them, you just can't write them back to the PCM without buying the hardware / credits. Hope this helps.
https://www.hptuners.com/downloads/ Last edited by Gregski; 10-18-2019 at 09:04 AM. |
#142 |
60-66 Nut
That is good to know. I might give that try this winter.
#143 | |
![]() Join Date: Jun 2015
Just so I`m getting this straight, I can go on the site, download the authentic software to my laptop. Then (without credits) I can practice on a test file from them or can I download a copy of my current tune and practice on it; just not writing it back to the pcm? Or do I need credits to copy my current program out to the laptop? The reasons I ask: I have an old OBD II cable from my 95 Trans Am Gen II SBC. (95 was a change over year, OBD I PCM with OBD II plug) I used it with Tuner Cat software for that year. Very basic program and not user friendly compared to the HP Tuner; but got the job done. if the cable will work with HP Tuner, my buy in to start this had gone down considerably. No need to buy their Bluetooth hook up, just credits.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
#144 | ||||
Great questions, allow me to clerify.
#145 |
What guys do, what I've done, and what I suggest you guys give a shot, is go to the junkyard and buy a PCM ie computer off of a 1999-2007 (Silverado, Sierra, Suburban, Tahoe, Yuckon) vehicle it really does not matter which one, but try to match it to your truck a bit, so if you have a 2WD then get one out of a two wheel drive, if you have a 4x4 than grab one out of a four wheel drive, if you plan on doing an automatic get one from a 4L60e transmission car, or 4L80e type of thing, if you want a stick than try and find one out of a NV3500 or NV4500 (good luck finding those) hee hee.
Then keep the blue connector for the PCM and cut about 3 feet of cable with it, you will make your own "Bench Harness" using this. This will allow you to tune this PCM or any other PCM off the car outside of the truck in your living room, your home office, or on the work bench in the garage, ie that's why it's called the Bench Harness, ha ha also get one OBDII port with about a foot of wire with it, you will also need that. I've included a link to a video on how to make one, this is Matt the Godfather of LS Swaps from Sloppy Mechanics you all should meet ha ha, 8-7-13 Stock computer bench flashing harness there are other videos that will come up so find one that works for you, I think I had to watch like three or four of them to see the different designs and flavors guys like to build / make, that's how all of this HP Tuners stuff works, there is no one 100% complete source you have to hunt and peck, this thread being no exception. frustrating at first, but it does get easier over time Last edited by Gregski; 10-16-2019 at 09:09 AM. |
#146 |
Thank you Gregski for taking the time to break down and document a very complex program into small logical bits that us neophytes can follow along and gain some comfort level without feeling buried and afraid of blowing things up. Your efforts and those of others like ChopperDoc are appreciated.
Have you taken a look at the Gen V LT programming with the HP Tuners and is it similar or very different? |
#147 |
Thank you Gregski,
This helps me wrap my head around what it will take to get into tuning.
#148 | ||
#149 | |
1. Change my RPM signal to 8 cylinders 2. Set my tire size 3. Here's my rear end gear ratio 4. Please turn off EGR and disable the associated diagnostic codes 5. Please turn off EVAP and disable the associated diagnostic codes 6. Please turn off the CAT heating and protection and disable the associated diagnostic codes 7. Please configure my fuel tank capacity for 16 gallons 8. Please turn off the speed limiter 9. Please enable Power Enrichment 10. etc, etc... please provide me with a copy of my Stock File before making any changes on a DVD or a USB stick please provide me with a copy of my New Tune File on a DVD or a USB stick hope this helps, G |
#150 |
sub'd
