Old 10-03-2019, 09:49 AM   #876
BigBird05
Re: What did you do to your truck today.The 3rd chapter
rechinca, that's exactly the same repair that I am working on.
BigBird05 is offline   Reply With Quote
Old 10-03-2019, 10:19 AM   #877
OregonNed
OregonNed's Avatar
Originally Posted by Steeveedee View Post
I was thinking quarter-sawn white oak. Either way, that is one beautiful bunch of work. I'd like to do something like this to my truck, but it would disappear down the rabbit hole of not being used for the rest of my life while it got worked on. I'm getting old.
Yep! My first choice was white, but the lumber yard didn't have enough of it at the time. Still, though, the wood was only about $225 if I remember right. My wood working friend did all the milling and finish work. But however my first choice was some flame patterned Myrtlewood that another friend harvested on his Southern Oregon coast farm, but the sawn lumber was not dried properly, and it all shifted and warped. My wood worker friend is using portions of it on other projects. That myrtlewood would have been pretty unique, though, and I wish I could have seen it finished. You can see some of the detail of that wood in this fishing net he made.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-03-2019, 10:26 AM   #878
1970GMC3500Longhorn
Originally Posted by Liz View Post
Chapter 2 is now complete, bring on 3. What did you do to your truck today?
Today I put new wiper blades, a new brake light switch, and new reverse lights in! But the passenger side reverse light is not working unfortunately.
1970 GMC 1 Ton 9 foot Stepside
1970GMC3500Longhorn is offline   Reply With Quote
Old 10-11-2019, 10:23 AM   #879
66clow
66clow's Avatar
Made a beverage holder😁
66clow is offline   Reply With Quote
Old 10-12-2019, 06:04 PM   #880
72c20customcamper
72c20customcamper's Avatar
Got the rear part of the cab's body work pretty much done. I'll epoxy prime it tomorrow and get some high build on it. Nice having ot to strip to bear metal. So far the drop rails look great.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-12-2019, 06:08 PM   #881
72c20customcamper
One more
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-12-2019, 08:31 PM   #882
tim_mc
tim_mc's Avatar
Nice work. Easy day for me. Replaced headlamps with Sylvania Silverstar sealed beams.
Changed my TH350 speedo driven gear from 20-tooth to a 24-tooth and verified the speedo with a GPS phone app - right on target. 5% per tooth rule of thumb worked for me as my speedo was reading 20% higher than GPS MPH. Added a spare tire carrier from LMC and bolted in the spare tire. Added a kill switch to the HEI tach lead and tested a few times - works great.
tim_mc is offline   Reply With Quote
Old 10-13-2019, 03:51 AM   #883
71gmcC15
71gmcC15's Avatar
I upgraded to led lights all round. Besides reverse or headlights.
https://youtu.be/nmTLkR-0obk
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 10-13-2019, 03:03 PM   #884
c10Eric
Found the exhaust leak 😄
c10Eric is offline   Reply With Quote
Old 10-13-2019, 03:07 PM   #885
66clow
66clow's Avatar
Originally Posted by c10Eric View Post
Found the exhaust leak ��
That's not called a cut out? ��
Old 10-13-2019, 03:15 PM   #886
66clow
66clow's Avatar
Painted the visors, stuff works great! Will do my seat next. Changed my kinked fuel line that was long overdue.
Old 10-13-2019, 04:26 PM   #887
c10Eric
I’ve got the new (old) manifold cleaned up and installed. Also new carb and distributor.
Old 10-13-2019, 09:47 PM   #888
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
I cleaned up a set last week for my daughters 68 step also. Wire brushed and wiped down with brake cleaner then painted black caliper paint.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-14-2019, 03:22 PM   #889
72c20customcamper
Painted the rear part of the cab. Paint area was a little too cool when I turned on the exhaust fan . I'm using a large ezup with sides . I got a couple minor sags but I got it in the sun now . Debating on whether I will fix them or just leave them. That's the price you pay for using single stage paint.
Not going for show a truck just a real nice driver. That you wont mind taking to a show
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-14-2019, 09:56 PM   #890
67C10Step
67C10Step's Avatar
No photos but got the upper rear shock mounts off and two of the four rivets in the rear most frame cross member out. I’m prepping to paint the rear of the frame and know I’ll be re locating the rear shocks so those parts gotta go.
Guess the truck was stuck at least once and someone connected the chain to that rear cross member and pulled a hickey in it. Buddy of mine has a spare frame so I’m gonna get a straight one from him but figured the frame would clean up better with the old cross member out. Hope I’m blasting the rear frame section this weekend.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-15-2019, 10:27 AM   #891
Andy4639
Old member
Andy4639's Avatar
Got the Delco-Pleasure lift gauge mounted and air up the air tank on the ramp truck then took it for a ride.
Old 10-20-2019, 08:02 PM   #892
67C10Step
67C10Step's Avatar
Lots of people would not call this progress but I know this crowd appreciates the level of time and effort to get to this point.
Started with just pulling the drive shaft and removing the long rear brake line. That went so well I decided to cut the springs out. Then that lead to cutting the rear end u bolts. What the heck, wonder if soaking the trailing arm bolts for weeks has paid off.
Now all I have to do is clean it all up. Got rust encapsulator and frame paint just need time and a pile of parts.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
Old 10-20-2019, 08:08 PM   #893
Beau2a
Beau2a's Avatar
Installed a new master cylinder. New NAPA calipers and hoses. Powerstop drilled & slotted rotors and pads. Stops great now. Pedal doesn’t sink to the floor at a stop light.
Beau2a is offline   Reply With Quote
Old 10-20-2019, 09:44 PM   #894
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I know it doesn't seem like progress but it is..Don't pay attention to what other people say....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-21-2019, 07:59 AM   #895
Grumpy old man
Grumpy old man's Avatar
Working on the power steering this week , This is a 67 short bed frame that wasn't dimpled for a power steering gear , at the bottom left of the picture you can see where I modified the frame just enough to fit the box without going crazy with heat and a BFH to make it fit , It really doesn't take much to have it fit and still look clean . Just waiting on the new pump and pulleys to show up and chase down some stainless steel lines .
Old 10-21-2019, 08:05 AM   #896
66clow
66clow's Avatar
Took it to my first judged show and received best of show for my class.
Old 10-21-2019, 08:37 AM   #897
Grumpy old man
Quaker steak and lube on 49th st ?
Old 10-21-2019, 08:39 AM   #898
66clow
66clow's Avatar
😉👍🏽 good eye!
Old 10-21-2019, 08:46 AM   #899
Grumpy old man
😉👍🏽 good eye!
Now take it to Biff Burger on Friday night .
Old 10-28-2019, 07:58 PM   #900
Grumpy old man
Got my power steering pump and stainless lines in today , One more bite off the elephant .
