10-12-2019, 10:00 AM | #1 |
Carb idling problems on 65' C-10 with 292
Need some help with my 1965 C-10. It has an original 292 with approx 158K miles, 3 speed on the tree. Recent tuneup, new plug wires, plugs, dist cap, points. condenser, new fuel pump and rebuilt 1 barrel Rochester with manual choke. Stock exhaust. I timed it 4 degrees btc, dwell at 31. It is hard to start and takes what seem to be a long time to warm up. The carb stumbles and pops back through the carb at times, not all the time. What am I missing here? Thanks for any info in advance.
10-12-2019, 10:03 AM | #2 |
Re: Carb idling problems on 65' C-10 with 292
Lack of timing and/or heat riser stuck.
10-12-2019, 10:34 AM | #3 |
geezer#99, thanks for responding. Here is a photo of my heat riser and it is frozen in that position. It almost looks to me like it has backed out some. What would be a quick fix on that? Also how much timing would be better that the 4 degrees BTC? Thanks.
10-12-2019, 10:44 AM | #4 |
Looks like it’s stuck open.
Try timing at 12. Be sure to plug off vac advance hose while setting timing. |
10-12-2019, 11:01 AM | #5 |
geezer#99, I'll be sure and plug off vacuum advance and try timing it at 12. Thanks.
10-12-2019, 11:54 AM | #6 |
Moderator
More timing makes it harder to start, not easier.
First thing I would do is triple check the plug wires, put it at TDC, and check the cap/rotor. This could be a firing order issue when I hear about the backfiring. |
10-12-2019, 12:13 PM | #7 |
jayoldschool, thanks for your input. I will check the position of the plug wires.
10-16-2019, 10:26 AM | #8 |
What kind of spark does it throw? It should be blue and jump a gap of about 1/4" or more.
The accelerator pump in the carb is working good? |
10-16-2019, 10:43 AM | #9 |
+1 on the plug wires first; it's an easy fix.
If it only pops through the carburetor when you're trying to accelerate, it sounds lean. Maybe lean mix, maybe a problem with the accelerator pump. By "hard to start" do you mean slow jerky cranking, or you have to crank it for a long time? And I have to ask - you're pulling the choke to get it running, correct? And slowly pushing it in as it warms up?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-17-2019, 11:39 PM | #10 |
I want to thank all that responded. Turned out to be part vacuum leak and timing. Thanks all.
