Old 10-20-2019, 12:08 AM   #1
msg
Trouble reinstalling stored rotors
Im unpacking stored rotors that I had removed years ago and thought I had enough pics of the teardown to help but this ones spotty. Ive unpacked a bag of parts and found that there is one washer part that I dont recall. And I only see one, which I would think two would be needed. The 66 I have had a disc brake conversion with parts from I think a 72.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-20-2019, 12:10 AM   #2
msg
Re: Trouble reinstalling stored rotors
This part here is the one I am asking about. The washer with a divot in it.
Old 10-20-2019, 12:41 AM   #3
SkinnyG
SkinnyG's Avatar
I've only ever seen the one toothed washer on all the vehicles I've done bearings on.
Is there some reason why you have extra washers? Are these the right rotors for your spindles?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-20-2019, 09:27 AM   #4
msg
These should be the correct rotors, they were isntalled by a local custom shop 3 years or more prior to me tearing things down. Never had any issues with them when I was driving iot all those years. I bagged up all I found as I did the tear down..maybe this was a spacer/shim? Maybe it wasnt supposed to even be there, im not sure.
Old 10-20-2019, 06:34 PM   #5
PGSigns
PGSigns's Avatar
I have seen extra washers in the past on stuff I have worked on. Most of the time they were needed to get the castle nu out far enough to get the cotter pin to work. The correct solution was the castle not correct and the one used was thinner. I would slide the rotor up on the spindle and see how things look.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
