Old 10-22-2019, 10:57 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: AC capacities needed and other questions
Per my notes from a couple years ago when I had a shop resurrect my factory A/C system:
R12 takes 3.75# (60 oz) + 10 oz oil.
R134a takes 80% of the R12 amount, so 48 oz.
That's all the info I have..... hope it helps.
I went with R134a, but these things were designed to use R12, and I understand it cools better. Since you have a source, that's probably the best choice.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-23-2019, 01:23 AM   #2
FirstOwner69
FirstOwner69's Avatar
The original label on my '69 said 3.25#.The amount was on a stick on label that looked like something from a Dymo label maker. Underneath it said 3.75#. The label went missing years ago, but I found the same label on a junkyard compressor. That label is now on my truck. I've always wondered if later years took 3.75 since they changed to crimped hoses sometime later than my truck was made.
Just looked at the '69 service manual. It says 3 lbs. 4 oz. of R-12 and 10 oz. of oil. Do you have a manual for your year?
FirstOwner69 is offline   Reply With Quote
Old 10-23-2019, 01:57 AM   #3
Rufas
Rufas's Avatar
Sure wish I did.
BTW here is a photo shortly after my Dad purchased this truck new in 1970.
After my restoration.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 10-23-2019, 10:15 AM   #4
FirstOwner69
Originally Posted by Rufas View Post
Sure wish I did.
Nice truck!
Here's a link to PDF service manuals.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
