Old 10-21-2019, 10:31 AM   #1
blazer2007
I keep loosing upper fender bolt
I keep loosing my upper right fender bolt and spacers by the windshield. It takes a month or 2 to loose them but am Leary about using lock tite in case I have to remove the fender in the future. I had to replace weld nut on my other truck and is was not fun when the bolt started twisting the nut on the body
blazer2007 is offline   Reply With Quote
Old 10-21-2019, 11:47 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: I keep loosing upper fender bolt
We built about 15 million squarebodies (so about 30 million fender attachments) and I have never heard of this phenomenon before.
You might want to look at the rest of the attachments and see if something else is causing this (ie, loose or bad radiator support cushions, other loose attachments or maybe too many shims at that location, etc).
In any case - I would think a little blue Loctite would be ok.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-21-2019, 11:49 AM   #3
SCOTI
SCOTI's Avatar
I've lost a few on my dually as well. I always no it because the truck starts creaking really bad over bumps all of a sudden. Sure enough, each time it happens, the bolt is missing again.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-21-2019, 12:14 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
can always use a little Teflon tape on it to keep it secured
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-21-2019, 05:15 PM   #5
SunSoaked
SunSoaked's Avatar
A good cross-thread beats locktite every time.
SunSoaked is offline   Reply With Quote
Old 10-21-2019, 06:12 PM   #6
Dead Parrot
If you are worried about spinning another weld nut, put the loctite on the nut head and shims. Not as secure but might be enough.
Dead Parrot is offline   Reply With Quote
Old 10-21-2019, 10:19 PM   #7
geezer#99
geezer#99's Avatar
Thread a piece of copper wire in with the bolt. The wire will meld into the threads and stay tight.
geezer#99 is online now   Reply With Quote
Old 10-21-2019, 11:05 PM   #8
SunSoaked
SunSoaked's Avatar
Meld? I had to look that one up. Lol
Old 10-22-2019, 12:31 AM   #9
mongocanfly
mongocanfly's Avatar
Nothing wrong with blue loctite....or maybe a lock washer under bolt?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-22-2019, 09:06 AM   #10
geezer#99
geezer#99's Avatar
I could have said ‘ooze’ but that’s kind of a creepy thought!
LOL!
Old 10-22-2019, 11:19 AM   #11
truckin 79
I just noticed Loctite has a new type of thread locker it is orange. Give that a try
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 10-22-2019, 12:27 PM   #12
Keith Seymore
Where does that fall in the spectrum of red vs blue?
K
1979-1986
1986 - 2019
Old 10-22-2019, 12:55 PM   #13
mongocanfly
I dont think the orange is meant for threads......https://www.fastenal.com/products/details/0150423
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-22-2019, 01:24 PM   #14
demian5
demian5's Avatar
The only things I could think that "over time" would cause this is:
1. Not having a bolt at the bottom of the fender under the cab, or a rusted fender that cant be secured.
2. A bent fender that the door hits when opening and closing.
3. Tires that rub the fenders when turning or going through dips and vibrate the fenders with the tread.
4. Off-roading on washboard roads.
5. Excessive shopping cart bashing at the local mall.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-22-2019, 02:21 PM   #15
mongocanfly
#5 ... haha....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-22-2019, 02:49 PM   #16
Llay R. Rac
Llay R. Rac's Avatar
a coating of solder on the threads works great, add a piece of thin copper wire if the fit is very loose.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 10-22-2019, 02:51 PM   #17
Keith Seymore
Ah - so it is a sealant.
K
1979-1986
1986 - 2019
Old 10-22-2019, 03:34 PM   #18
SCOTI
SCOTI's Avatar
1. Not having a bolt at the bottom of the fender under the cab, or a rusted fender that cant be secured. I'd have to dbl check that but if I remember all other hardware was in place for mine.
2. A bent fender that the door hits when opening and closing. No interference @ the doors. A couple of small door dings only on my OE sheet metal.
3. Tires that rub the fenders when turning or going through dips and vibrate the fenders with the tread. Aftermarket raised inner fender wells so no rubbing except for the seldom buzz (happened maybe 3-4 times since 2015) if turned too sharp while navigating a dip/driveway entrance.
4. Off-roading on washboard roads. Only 'off-roading' mine experiences is an occasional field maybe at idle speed. Now our regular pothole infested roads are a different story....
5. Excessive shopping cart bashing at the local mall. 2x parking lot bruises. Other than that, no shopping cart bashing.
While anything is possible....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2019, 09:18 AM   #19
Big Chip
Big Chip's Avatar
https://www.permatex.com/products/th...-threadlocker/
There's also this stuff.
Big Chip is offline   Reply With Quote
Old 10-24-2019, 09:51 AM   #20
blazer2007
I think I will tie a string around the bolt like little kids mittens so I don,t loose it
Old 10-24-2019, 10:30 PM   #21
mongocanfly
Any way to safety wire it?....drill a hole thru the head...tighten bolt ...run wire thru hole and fasten to something
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-24-2019, 10:51 PM   #22
SunSoaked
SunSoaked's Avatar
21 posts regarding a loose bolt. Lol.
Old 10-27-2019, 10:48 AM   #23
kidatheart
kidatheart's Avatar
We are up to 23 now!!
kidatheart is offline   Reply With Quote
Old 10-27-2019, 10:57 AM   #24
1976gmc20
Well, if your bolt is loose then you may lose it
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 11-06-2019, 08:01 PM   #25
Factory Guy
Factory Guy's Avatar
My guess is you have a vibration problem you may not feel but your bolt and fender are feeling it, that’s why they keep vibrating out.
Don’t put a bandaid on your knee when the cut is on your finger.
Rather than patch the problem, I would look at trying to solve the issue.
Factory Guy is offline   Reply With Quote
