Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 10-27-2019, 05:06 PM   #26
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Suburban metal cuts
What is circled in red Richard....needing the last 3-4" of roof from drip rail flange to 1/2" above body line. Need around 40" of length.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-27-2019, 05:17 PM   #27
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I really don't know why I am being so dense on this, I just keep looking at the pic you posted and it looks like you need the part i have the yellow arrow at. Or is that what you were trying to cut and went too high into the roof half?
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 10-27-2019, 05:19 PM   #28
richard2717
I think i am going to go lay down and revisit it in the morning.
Members I have met.
Old 10-27-2019, 10:14 PM   #29
71blksuper4x4
SWB 4x4 Collector
Hey Richard, this is what I am trying to fill in. This should explain I need the drip rail flange on the roof that gets spot welded to the drip railing. Then I am asking you to cut it just above the extra body line that a Burb roof has. I burnt through one of mine when I was trying to remove it.
TREVOR
Old 10-28-2019, 07:55 AM   #30
richard2717
Josh
$75 shipped for both pcs
Members I have met.
Old 10-28-2019, 07:57 AM   #31
richard2717
Trevor,
I am understanding what you need. I will get it cut out later today. $25 plus shipping. Not sure if I still have your address but should be able to locate on PP
Richard
Members I have met.
Old 10-28-2019, 03:27 PM   #32
richard2717
Trevor
Here is what I cut out. I unbolted it from the lower half. The pc is just shy of 48" just bc it made no difference in the shipping cost from 40''. anything longer than 48'' and the cost almost doubled being over sized. If I did not cut it correctly I still have the entire driver side to try again lol. $55 shipped if it is correct. PP in my sig below
Members I have met.
Old 10-28-2019, 08:08 PM   #33
71blksuper4x4
SWB 4x4 Collector
Originally Posted by richard2717 View Post
Trevor
Perfect Richard, PayPal sent. Thanks again, Trevor
TREVOR
Old 10-28-2019, 08:47 PM   #34
richard2717
Got it and it will ship in the morning as well. Thanks
Members I have met.
Old 11-02-2019, 11:53 AM   #35
71blksuper4x4
SWB 4x4 Collector
Thanks Richard, I got the piece yesterday. Looks great. Trevor
TREVOR
Old 11-22-2019, 08:11 PM   #36
71blksuper4x4
SWB 4x4 Collector
Richard did you end up scrapping these out? Trevor
TREVOR
Old 11-22-2019, 08:14 PM   #37
richard2717
I still have quite a bit
Members I have met.
Old 11-23-2019, 12:14 AM   #38
71blksuper4x4
SWB 4x4 Collector
Richard, I may be needing a 8-10” piece of inner pillar off a driver’s inner b pillar. I’ll let you know tomorrow.
TREVOR
Old 11-23-2019, 02:33 PM   #39
richard2717
here is pics of what is left both have been cut pretty much flush at the front of them heading towards the A pillar
Members I have met.
Old 11-23-2019, 03:41 PM   #40
71blksuper4x4
SWB 4x4 Collector
Actually Richard, those are perfect for me. I am working on finishing my inner roof and need pieces to transition from the pillars to the I need roof as shown. Before I finish welding and grinding, I wanted to get a game plan.
TREVOR
Old 11-23-2019, 05:46 PM   #41
richard2717
So you basically only need the inner metal overlay like I have boxed here, or do you need the entire thickness of it all the way to the outside roof?
DO you need any of the horizontal cover above the doors?
Members I have met.
Old 11-24-2019, 12:00 AM   #42
71blksuper4x4
SWB 4x4 Collector
Basically, that is all I need Richard. I do not need any of the pieces above the door. I already have my whole inner roof mocked up other than finishing it out and these pieces. If you can cut out both of those for me as I need two for each side. Maybe 3" inches below the door weatherstrip channel intersection but above the shoulder harness hole. Thanks Trevor
TREVOR
Old 11-24-2019, 12:10 PM   #43
shume
Junior Member
Looking for drivers side rear frame section from axle crossmember to bumper. I need it for a Blazer. If you have one from Suburban hoping it might work.
shume is offline   Reply With Quote
Old 11-24-2019, 12:18 PM   #44
richard2717
The tail end of the suburban is different from the 72' Blazers. Here are a couple pictures to show the difference. If your Blazer is 69-71 the frame just cuts off flat at the rear but I do not have one here to verify if they are indeed swapable.
1st picture shows suburban tail end
2nd pic shows how the blazer turns down a lot sharper. This frame is not for sale. You might check with 1Rippen6 he usually has some blazer stuff
Members I have met.
Old 11-24-2019, 02:37 PM   #45
shume
Junior Member
Thanks. With the turn down on Blazer not sure I could make the Suburban piece work.
Old 11-26-2019, 10:30 PM   #46
71blksuper4x4
SWB 4x4 Collector
Hey Richard, these would work.
TREVOR
Old 12-25-2019, 04:54 PM   #47
kev2809
low n' slo
kev2809's Avatar
are ya still parting these out? i need this section, its driver side back wheel arch area.. piece i used did not have the wheel arch indention..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-26-2019, 06:06 PM   #48
richard2717
Missed this with the holidays. I do not have ant good lower metal, everything is rusty or totally gone
Members I have met.
Old 12-27-2019, 12:27 AM   #49
kev2809
low n' slo
kev2809's Avatar
ok thanks for checkin!
-_--_--_ _________
Old 01-11-2020, 11:31 PM   #50
ajgriffin
ajgriffin's Avatar
I see you said you don't have any good lower metal, what about the driver's rear wheel well? I need a small section at the front, 4" up and 3" toward the rear to include the corner.
I can take a better picture with tape on the wheel well if it would communicate better. This is the area I'm trying to patch.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
