![]() Join Date: Mar 2012
thoughts and opinions
I am chomping at the bit to hit the order button on a Dakota Digital Gage board. I am down to either the HDX or the RTX series.
RTX looks a little more original to me. what are your thought and any experience or concerns with DD. and yes I know there are the Purist OEM guys that will say "NO WAY" out there and your info is welcome too.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Jun 2009
Re: thoughts and opinions
I definitely prefer the RTX. Not to muddy your waters but have you looked at new vintage USA? They have some good looking ones. Especially retro ones.
http://newvintageusallc.mybigcommerc...ew-category-3/ |
![]() Join Date: Oct 2014
My choice would be Classic Instruments. Check them out if you haven't already.
https://shop.classicinstruments.com/...-truck-package
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#4 | |
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
Holy Schneikes those gauge packages are expensive!!!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Well I pulled the plug in the RTX series with a couple of add ons trans temp and outside temp and compass sensors. Waiting for them to arrive
Looking forward to hearing a review from you on these. I have decided on the RTX gauges as my next purchase. I like the look coupled with the more modern features.
As far as a review. It will be a long while before I get them Installed and running
But at least they are in the garage now on the shelf
Old member
I like my 'Speed Hut gauges' GPS speedometer and no calibrating it just drive it. Life time warranty also.
Yes all the new gauges are expensive. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
