11-04-2019, 04:42 PM | #1 |
Dash lights help
I have 1970 c10 396 bbc 1/2 ton and was trying to figure out why my dash lights dont work and my fuel gauge and I stumbled on this black wire with a blub not connected to anything and was wondering if need to be connected somewhere and if that's the cause why my gauge lights dont work. Also notice this grey wire with something on it dont know its for.I'll appreciate the feedback. P.s I'm new to this its my first car and learning bout this truck.
11-04-2019, 05:38 PM | #2 |
Re: Dash lights help
The first one is the shift indicator bulb it plugs into the back of the cluster the second pic looks like it’s for your heater control bulb
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 11-04-2019 at 05:44 PM. Reason: . |
11-04-2019, 05:52 PM | #3 |
Your dash lights probably don't work because the headlights switch is probably bad, there is a variable resistor (would wire) visible where it mounts, it provides dash light dimmer function, they go bad and or have bad spots.
Fuel gauge is probably the sending unit or float. If the gauge goes to or sits at 3 o clock, the gauge probably has power and ground. The tan fuel gauge wire at the fuse box upper right could have come loose or the wire on the sending unit could have come loose. Unhooking it and or plugging it in should make the gauge move, if it goes to empty when connected and you know its not empty then the float is probably bad. |
11-04-2019, 06:45 PM | #4 |
I disconnected the tan wire and the fuel gauge doesnt move at all. I replaced the fuel gauge and going to see if it moves when I disconnect the tan wire. You could be right my light switch acts up sometimes doesnt work or cab light goes on without touching switch.
11-04-2019, 07:22 PM | #5 |
Why didn't you check for power and ground?
There is a fuse, cluster feed, upper right, Does the temp gauge work? It powers that too. |
11-05-2019, 12:27 AM | #6 | |
The Older Generation
The heater control bulb holder snaps into the hole in the back of the heater control assembly. (pic 2) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-05-2019 at 12:33 AM. |
11-05-2019, 07:55 AM | #7 |
http://outintheshop.com/faq/wiring/w...s/image002.jpg
http://outintheshop.com/faq/wiring/w...s/image003.jpg I would start out with a test light or multimeter and work your way from one end to the other. Make sure you have power and ground at the connector for the cluster. I don't know the terminals on the gauge, but you should be able to find that here somewhere. Cluster lights circuit: bulbs printed circuit board on the back of the cluster 20 gauge Gray wire fuse block 16 gauge Dark Green Light switch
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
11-06-2019, 01:17 PM | #8 |
11-06-2019, 02:22 PM | #9 |
Still Green but learning
those two run off of other cables and not necessarily the circuit board dont they? Sound like the wiring harness or ckt board may be shot. But I dont have a gauge cluster, so not sure.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
