11-07-2019, 11:15 AM | #1 |
Transmission cooler needed?
Good Morning,
So i am continuing my build on a 72 K10, and we have purchased a Mishimoto 3 core Aluminum Radiator. I have new steel trans lines from the TH350. My question is: do i need to install an aftermarket transmission cooler? I have a trans cooler just in case but if not needed it saves an extra step and also keeps the core support area cleaner and free of less stuff. Suggestions and comments please. |
11-07-2019, 11:37 AM | #2 |
20' Daredevil (Ret)
Re: Transmission cooler needed?
If your powertrain is pretty much stock -- and if the radiator has a built-in trans cooler -- you shouldn't need an aftermarket cooler.
If you're building a hotrod or a workhorse that will see severe duty, I would add one.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-07-2019, 11:40 AM | #3 |
this vehicle is stock with all the stock powertrain rebuilt. thank you very much for the response.
11-07-2019, 11:49 AM | #4 | ||
"I ain't nobody, dork."
A trans cooler is never a bad idea. But like mentioned above, you might not really NEED one.
Gary
11-07-2019, 12:30 PM | #5 |
Old member
My personal opinion is if you have it install it. You never know when you may need to pull something and instead of wishing you could have pulled it and not. I would install it just for good insurance on keeping the trans temp below 200* no matter what you used it for.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-07-2019, 01:25 PM | #6 |
20' Daredevil (Ret)
So the new radiator has a built-in trans cooler?
11-07-2019, 03:48 PM | #7 |
As said with a stock motor you dont need one. A high stall torque converter and/or a high hp engine is when you need extra cooling.
11-07-2019, 05:00 PM | #8 |
11-07-2019, 05:26 PM | #9 |
20' Daredevil (Ret)
Ah, perfect! You're all set. I asked because some radiators have no provision for trans cooling -- in which case a separate cooler would be called for, even with a stock drivetrain. You are good to go!
11-07-2019, 07:37 PM | #10 | |
Something I feel an automatic transmission equipped truck should have is a transmission temperature gauge.
11-07-2019, 07:55 PM | #11 |
thank you all for your support.
11-08-2019, 11:48 AM | #12 | |
Who Changed This?
