Old 11-07-2019, 01:28 PM   #1
msg
Rear suspension install questions on a 66
When I did the tear down years back the coils had only this hardware in the pic holding it in. The manual is a bit different even though its a 63 manual I figured its close. But the 63 must have had a welded square bolt there. In my case there is no welded square nut just a hole. So I think its just one nut holding the coil on...seemed like it might need a washer but I guess it doesnt. This seem right to go with? Or is adding a beefy washer going to help? In the pic I havent tightened up the top bolt yet.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 11-07-2019, 02:18 PM   #2
Clyde65
Clyde65's Avatar
Re: Rear suspension install questions on a 66
You need new retainer plates and bolts, grade 8 would be beat.
Here are the plates.
https://www.classicparts.com/mobile/...info/74%2D575/
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-07-2019, 02:55 PM   #3
msg
Thanks Clyde, I kept the ones I took off and sandblasted and epoxy primered them all. I hope its not a no-no to reuse them?
Old 11-07-2019, 03:02 PM   #4
msg
Also, got a question on the alignment of the coil and the retainer. I have a pic of what it looked like before I removed it. But from what Im seeing in the assembly manual the coil curls upward and into the notch of the retainer.
Old 11-07-2019, 03:05 PM   #5
msg
Currently I set it up like so to match the pic from before the removal.
Old 11-07-2019, 03:17 PM   #6
PGSigns
PGSigns's Avatar
I always replace the bolts. Just don't trust 50 plus year old bolts that were rusty.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-08-2019, 10:56 AM   #7
Clyde65
Clyde65's Avatar
I agree with PGsigns! Replace the bolts, cheap insurance!
Clyde65
Rebuild of Clyde
support our troops!
Old 11-08-2019, 01:09 PM   #8
msg
Just went on my lunch break to Ace. $12 worth insurance!
Old 11-08-2019, 01:13 PM   #9
msg
Doubled up on the washer, the ones at Ace were a little thinner than what was on there...plus the original was pretty curvy from the pressure over the years.
Old 11-08-2019, 01:16 PM   #10
msg
So what do ya'll think about the retaining cup notch alignment thing I mentioned above? I guess going back to what it was doing originally is fine since I cant get the notch thing to click in place since the coil slopes downward vs the upcurve in the manual illustration.
