Old 11-09-2019, 02:33 AM   #1
BCOWANWHEELS
I need a engine hose..............
Theres a hose on the passenger side valve cover that goes to the rear of the carb air filter spacer just under the air filter. Its some sort of crankcase vent. It has a factory 90 degree bend on valve cover end. Does anybody know where i can buy one of these. My engine is a 350. 1972 c10..................thanks
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-09-2019, 08:41 AM   #2
Boog
laying low
Boog's Avatar
Re: I need a engine hose..............
Bob I checked LMC catalog and they don't offer it. Brothers might. A quick check showed at least one used spacer and hose have been sold in the classifieds each of the last few months. If someone could get you the ID and length of the hose you may be able to scour the auto parts books for one similar but for a different application. Ebay possibly? Google AC Delco parts?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-09-2019, 09:08 AM   #3
rsavage
rsavage's Avatar
PM some guys that sell regularly on here - Specialty Retail? as an example.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-09-2019, 09:08 AM   #4
saxart
saxart's Avatar
I'm not certain if this is the correct size, but maybe this will get you started:
https://www.autozone.com/emission-co...E&gclsrc=aw.ds
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 11-09-2019, 10:48 AM   #5
Willys_MB
Willys_MB's Avatar
There was a lengthy discussion about this on the forum last week.
http://67-72chevytrucks.com/vboard/s...&highlight=PCV
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 11-09-2019, 11:23 AM   #6
rsavage
rsavage's Avatar
I do not believe the OP is talking about a PCV hose. I beieve he is referring to the hose that goes from the passenger side grommet to the carb spacer. It is a vent hose that allows crankcase gasses to be burned. Larger diameter than a PCV hose and has a special end on it.
1961 C1 Corvette
2021 Durango RT 5.7
Old 11-09-2019, 02:16 PM   #7
BCOWANWHEELS
Rsavage , yep that is it............... Crankcase vent hose
Old 11-09-2019, 03:25 PM   #8
dmjlambert
dmjlambert's Avatar
The part that it plugs into on the valve cover (or special end) is a flame arrester. Are you looking for that as well? You can probably get the flame arrester and/or hose by posting a want to buy ad in the parts section.
The grommet for the valve cover is Dorman 42052 or GM part 14091870, I got one at the local Chevy dealer and later got the Dorman part on eBay.
Old 11-09-2019, 07:13 PM   #9
Tman
Tman's Avatar
I found a molded heater hose off of a newer pickup of some sort at the local auto parts store that was the right size and had a 90 bend with enough length on each side. Cut out what I needed and stashed away the rest.
Tman is offline   Reply With Quote
Old 11-09-2019, 07:32 PM   #10
BCOWANWHEELS
hose is 3/4 i.d. I got a new grommet. just need new hose.
Old 11-10-2019, 02:41 PM   #11
toolboxchev
Is DC Trucks still on here? He has dismantled alot of our year models.
Odds are he has one.
toolboxchev is offline   Reply With Quote
Old 11-10-2019, 04:24 PM   #12
BCOWANWHEELS
I want a new hose, i have originl one
Old 11-10-2019, 06:42 PM   #13
toolboxchev
Yes, my bad, I was thinking mine was constructed out of metal...just checked.
I can see now!
