Old 11-10-2019, 08:14 PM   #1
HeloCrewChief
HeloCrewChief's Avatar
Differences between 1972 2wd 350 and 4x4 350
I will be returning my 72' 3/4 4x4 Suburban engine compartment back to stock. I found a complete 1972 2wd truck 350 to swap in but, was curious what is different between 2wd and 4wd? I know the radiator hose pipe is and that is about it as far as my knowledge on the subject goes. Anything else different on the 4wd 350 engine compartments? Thanks in advance.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 11-10-2019, 11:13 PM   #2
B. W.
B. W.'s Avatar
Re: Differences between 1972 2wd 350 and 4x4 350
If it has A/C the vacuum can mounted to the AC box has an offset bracket on the 4x4. I'm guessing it gives more clearance to the valve cover because the motor is set back?
B. W. is offline   Reply With Quote
Old 11-11-2019, 12:51 AM   #3
Dipstick and tube is longer and bends forward on 4wd
Old 11-12-2019, 01:29 AM   #4
HeloCrewChief
Good information guys. Non A/C ruck.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 11-21-2019, 12:15 AM   #5
Blazerowner
Blazerowner's Avatar
Engine mounts?
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 12-17-2019, 02:51 AM   #6
Greasey Harley
Greasey Harley's Avatar
not sure about '72 but, my '68C10 uses front motor mount location and my '68 K20 used rear motor mount location in order for the oil pan to clear the front axle.
Greasey Harley is offline   Reply With Quote
Old 01-03-2020, 11:28 PM   #7
Eagle9502
Would this have been ‘72 only?
Eagle9502 is offline   Reply With Quote
Old 01-03-2020, 11:29 PM   #8
Eagle9502
Fan shroud is different for 4x4.
Old 01-06-2020, 09:31 PM   #9
jimbosprint
jimbosprint's Avatar
Throttle cable is shorter on 4x4 ('71-72).
jimbosprint is offline   Reply With Quote
Old 01-07-2020, 08:12 AM   #10
rsavage
rsavage's Avatar
I don't know if/when it might have changed year wise, but the AC vacuum canister on the 4X4's was metal whereas the 2WD were plastic. Won't apply to your non AC truck obviously.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-07-2020, 10:51 AM   #11
jimbosprint
Exhaust manifolds are also different. On 4x4 they go straight down, and on 2wd they angle back.
