Old 05-16-2014, 01:13 PM   #1
datguy
Reverse Lights!
so my truck does not have reverse lights. and i see most 60-66 trucks do, which ones are the right ones to buy i cant seem to find them in catalog books or online. i want to paint my truck soon and it would be a good idea to get the reverse lights installed before then.
datguy is offline   Reply With Quote
Old 05-16-2014, 01:16 PM   #2
1963c-10
1963c-10's Avatar
Re: Reverse Lights!
Were standard option in 66 I believe and optioned prior to that.
Do you have a fleetside or a stepside?
1964 Short bed trailer
Old 05-16-2014, 01:23 PM   #3
datguy
Re: Reverse Lights!
1963 Chevy c10 shortbed fleetside
Old 05-16-2014, 01:26 PM   #4
1963c-10
1963c-10's Avatar
Re: Reverse Lights!
Classic parts has them....heres the link : http://www.classicparts.com/1960-66-.../#.U3ZJ-RNOWUk
Old 05-16-2014, 01:29 PM   #5
datguy
Re: Reverse Lights!
thanks, all i would need to do is cut out the whole correct? then these would go right in. no need to purchase anything else?
Old 05-16-2014, 01:47 PM   #6
1963c-10
1963c-10's Avatar
Re: Reverse Lights!
Correct. Your harness may or may not have the provision to hook up the lights. If not, an aftermarket harness for the bed will have it. I ordered my rear harness from classic parts a few years ago and it had the provision even though I do not use it. I can post some install instructions for you.
Old 05-16-2014, 01:50 PM   #7
datguy
Re: Reverse Lights!
that would be great thankyou!
Old 05-16-2014, 02:03 PM   #8
1963c-10
1963c-10's Avatar
Re: Reverse Lights!
I'll post stepside, fleetside and suburban instructions. Column and manual shift in case it helps anyone else.
Old 05-16-2014, 03:59 PM   #9
jtrichard
Re: Reverse Lights!
hardest thing you will have to deal with is the switch to turn them on unless your trans cover has been replaced with a later one that has the switch in it .... if you look above at page 318 you can see what they used in 63 with the 4 speed
jtrichard is offline   Reply With Quote
Old 11-10-2019, 12:21 PM   #10
sstock
sstock's Avatar
Re: Reverse Lights!
Great instructions but without the locating templates, what do you do?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 11-11-2019, 03:34 PM   #11
G8rN@te61
Re: Reverse Lights!
Mine are actually a dealer installed(I think) mounted on brackets above the brake light and not in the fender. I know these are available online. I bought the classic parts rear lights wiring harness. Worked great. My backup lights are switched via toggle on dash right now though via my shadetree mechanic uncle.
G8rN@te61 is offline   Reply With Quote
Old 11-12-2019, 01:50 AM   #12
Bushman66
Re: Reverse Lights!
My 66 Stepside with the SM-420 also had this type of (unobtanium) switch. I have the brackets and the old inoperable switch, I'm hoping I can rig up a brake light switch that will work.
Bushman66 is offline   Reply With Quote
Old 11-13-2019, 12:37 AM   #13
Dhaak64
Re: Reverse Lights!
I’m looking to install taillights on my fleet side too. I have everything gathered, just need to find a template, or another fleet side with the factory holes already there so I can do some measuring. I want to make sure I’m 100% on this before I start cutting.
Dhaak64 is offline   Reply With Quote
Old 11-15-2019, 01:22 PM   #14
sstock
sstock's Avatar
Re: Reverse Lights!
Could you make available your measurements?
Old 11-15-2019, 02:22 PM   #15
oem4me
oem4me's Avatar
Re: Reverse Lights!
The search feature here is your friend.
