Hood spring problem
Hey guys. I had to replace the hood on my 66 K10 pick up truck. I bought one from LMC. I put it on today and it acts as if the springs are too strong for this hood. I have seen this happen on other trucks where the hood actually bends where are the hinges bolts onto it. My question; do I need to buy different springs?
peace Bud ![]() 1966 C10 4X4 1962 Impala Sport Coupe 1974 Corvette Coupe 1987 Suburban |
![]() Join Date: Dec 2009
Re: Hood spring problem
You could call LMC and ask them if their hood springs
they sell would be a good match (lower tension pressure than original) for the hood you purchased (From Them). Link: https://www.lmctruck.com/1960-66-che...ood-components You could search for Low tension hood springs. They make them for some vehicles. Maybe springs for a fiberglass hood? .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Thanks for the reply. I plan to call them. But after a google search they recommend lubing the hinges.
Posted via Mobile Device |
![]() Join Date: Jan 2011
Pull the hinges and springs back off and make sure the hinges work freely and work lube into them while they are off. Makes it a a lot easier to get the lube fully into the pins. I work lithium grease or gear lube. Doing it this way has worked well.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Chevy addict
Start by oiling all the pivot points on the hinges. As you close the hood push back on it to give the hinges a head start
| Bookmarks |
