LSA guys in here..fuel pump?
What intank fuel pump are you square body lsa guys using?
255 is not enough. Want to see what other size pumps will fit stock sending unit. Don't really want to go with high dollar tank setup.(IE holley/tanksinc) If I don't HAVE to.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#2 | |
BMW & ASE Master Certified
Re: LSA guys in here..fuel pump?
Side note, man it's been a long time since I've seen you screen name. This is what I'm using in my builds, custom fabed backets thats fits the stock sending unit And this one for a gen5 swap ![]() Only downsize is the electrical fitting, the spec sheet only goes to 14a, and terminals go to 16ga only. So if your gonna be drawing more than that, prob gonna need to run some wired through a fitting or something.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 11-28-2019 at 11:51 PM. |
long time...indeed
255 not enough....450 good. BUT, does the wider pump bottom fit the stock sender....? see above.
#4 | |
Just edited the post ![]() Here's a pic of the bracket ![]()
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Doesn't someone like Racetronix make an upgraded bulkhead connector for the bigger pumps?
#6 | |
That's why I designed and made my own hat to fit exactly like stock. It uses larger connector assembly which can handle more current if needed. Racetronix sells the 4 pin bulkhead shown In the above picture, but its still stock rated amps. Was a stock setup using the 6an bulhead for the e85 build part. ![]() This is the hat that fits like stock ![]() Uses 90* bulkhead fittings, an to forgot which fitting, but goes to holley plastic fuel line. Level sender was an to compression fitting which holds it in place. Clint
Ok I see. Will that connector fit in a stock sending unit with a little work? Do you have a part number for it?
#8 | |
I dont offer part numbers for connectors since it takes time, sometimes hour or more to track them down. I have one new yellow bulhead and mating outside tank side connector. No o-ring or retaining bracket. Original or new aftermarket will work fine. Basically heat gun the inside of the connector to soften it up and can pull it apart. Terminals, I might have, I'll update post later, but with no terminals, 14 shipped I'd your in the UsA. Clint
Need more pics of that the setup from the custom hat. The other end.
Looks good
![]() Wound up removing the aluminum tube as the return and used the stock return. Turns out the itty bitty pressures that build up in a sealed gas tank will.force fuel up that dang tube and make a mess ![]() I've got one hat, left. Had 2 made and would consider making more Clint I used the e85 safe in tank corrugated hose.. could have used a strait piece of in tank fuel hose if no e85.
255 was plenty to feed my LSA running 60lb injectors, ran out of cam before i ran out of fuel pump
#12 | |
I won't be doing that.
ok. glad i could help.
Sounds like you got this figured out already but I wound up going with a 320 lph pump on a 87 TBI hanger with a Racetronix C43 Bulkhead Wiring Assembly. That Racetronix wiring uses a 4 pin bulkhead like pictured above (not sure if it's the same one or not) with dual power leads to handle the bigger pumps. Most likely overkill for my HCI LQ9 that's going in my K5 (450hp or so) but I kept find conflicting info about what a 255 pump can handle and didn't want to run in to issues later on and have to drop the tank.
#15 |
![]() Join Date: Dec 1999
I will be running the Vaporworx controller using map reference for flow with the stock ZL1 pump on my LSA swap. Met up with Carl as he is local to me. Seems like a solid solution to me. Also has system that runs single or dual CTS-V pumps
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#16 |
Elaborate...and pics. Would love to hear and see more of this.
#17 |
Sorry no pics. Not that far along yet Installing motor and trans first of the year. Not a square body sorry. Using a 91 Chevy Blazer tank in my 72 with an adapter plate and ring welded in to accept the ZL1 pump. Modifying the pickup depth on the ZL1 pump for the tank. His website is here https://www.vaporworx.com/ Saw a bench set up running and also his 600+ hp LS supercharged 68 Camaro running on it (Whipple I think). Super quiet- pump, not the car
![]() Wanted to add he said he had a deal worked with a big name brand company to start distributing his product. They backed out due to the investment made in the current return type fuel systems. The owner of that company runs Vaporworx controllers in his own cars LOL.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-10-2019 at 03:52 AM. Reason: Add information |
