Old 11-25-2019, 04:05 PM   #1
jcwren
Correct installation of inner fender brace?
Not sure which way this brace is supposed to be installed. The impressions in the paint suggest that the larger edge was facing up. But this causes the alternator cable to run directly across it, which doesn't make sense. Unless, of course, the alternator cable is routed incorrectly... The brace doesn't fit as well if it's flipped over.
The alternator cable has a anchor pin that goes nicely in a hole in the inner fender (just off of picture left). There's a hole in the frame that it might could be moved to, but then the cable has a lot of excess between the anchor and the alternator.
I didn't take it apart, so not sure how it's supposed to go back together correctly. Unfortunately, in either case, the aftermarket inner fender bolt holes don't line up with the brace, so there's going to have to be a little rework done.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 11-25-2019, 07:02 PM   #2
jimelfarm
Re: Correct installation of inner fender brace?
The way you have it now is how mine was when I took it apart. You have to align the last two holes with a punch to pull the inner fender into shape to fit the bracket. Don't know about the electrical wire, I had no issues but my alternator is now a one wire.
jimelfarm is offline   Reply With Quote
Old 11-25-2019, 07:07 PM   #3
PepperTreeGarage
PepperTreeGarage's Avatar
This is how mine will go back once I finish the build. '72 C20. Hope it helps.
PepperTreeGarage is offline   Reply With Quote
Old 11-25-2019, 07:59 PM   #4
jcwren
OK, that makes the most sense. With a little coercion I got it installed.
Thanks!
1971 Dodge Dart
Old 11-26-2019, 08:42 PM   #5
PepperTreeGarage
Thanks!
Glad it helped. Wished I was putting that part back in. It's going to be awhile. This is where we're at in the build.
Old 11-27-2019, 08:59 AM   #6
Happy_dan
Happy_dan's Avatar
Can you post a higher res picture of that engine stand. I want to make one and it looks nice and simple. Where does it attach to the block?
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 11-27-2019, 09:22 AM   #7
jcwren
You can get them at Jegs or Summit. They're engine cradles. They're between $30 and $70.
1971 Dodge Dart
Old 11-27-2019, 09:33 AM   #8
Happy_dan
Happy_dan's Avatar
Yes, but I have scrap metal tubing in the shop and a welder so easy enough to make. I am sure I can figure it out but be nice to see one done.
2019 Silverado
2012 Camaro ZL1
Old 11-27-2019, 09:56 AM   #9
jcwren
To the engine mount holes in the front, and two or four of the bellhousing holes. If you google for 'engine cradle' and switch to the images tabs, there are thousands of images showing cradles with and without engines in them, in very high resolution.
1971 Dodge Dart
Old 11-27-2019, 10:30 AM   #10
Happy_dan
Happy_dan's Avatar
Excellent, thank you
2019 Silverado
2012 Camaro ZL1
Old 11-27-2019, 10:45 AM   #11
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Peppertree...can you give me the dimensions on your 2 x 4 stands you have under your tires? I need to build a set of these. Thanks
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-27-2019, 03:44 PM   #12
jcwren
https://restocar.com/blog/how-to-mak...en-car-stands/
Decent instructions. Don't make them so tall you can't get them under your wheels with your floor jack. My floor jack as 12" of lift, IIRC. You've got to account how far your suspension drops when you jack the frame up, and make them short enough to get under the tire.
1971 Dodge Dart
Old 11-28-2019, 03:19 PM   #13
dmjlambert
dmjlambert's Avatar
That is interesting. I wonder if people make dollies with that same method, by just adding casters. How many pound capacity would be appropriate for choosing casters do you think? Or is attempting something like that unsafe?
Old 11-28-2019, 04:31 PM   #14
PepperTreeGarage
2X4's and deck screws, for all your lifting and moving needs. The DANA 60 is around 500 lbs. and when you're a one man shop you get creative.
Old 11-28-2019, 06:00 PM   #15
jcwren
How'd you get it high enough to get the wheel cradles and the jackstands under it?
1971 Dodge Dart
Old 11-28-2019, 08:58 PM   #16
PepperTreeGarage
Lift with floor jack and put 4X4 under tires. Lower and then add 4X6 on top of floor jack and lift again.
Old 11-28-2019, 09:37 PM   #17
dmjlambert
dmjlambert's Avatar
Funny thread, turned down a different gravel road. Useful info, I like it.
