Old 11-28-2019, 11:44 AM   #1
71gmclongbed
air compressor
Where is everyone putting there tank and air compressors for bagging a 1971 c10?
71gmclongbed is offline   Reply With Quote
Old 11-28-2019, 01:41 PM   #2
jgrote
jgrote's Avatar
Re: air compressor
A lot depends on what look you're going for. I've seen them in the bed and on the frame rail. Where are you going to mount your solenoids? Are you going with individual solenoids, or one of those fancy blocks? I like the idea of showing it off, but plan on using my bed for real truck stuff. I'm going to be hiding mine.
jgrote is offline   Reply With Quote
Old 11-28-2019, 02:52 PM   #3
Sheepdip
Sheepdip's Avatar
Re: air compressor
My son stuck his along the outer frame rails just behind the front bed panel. Seemed like a perfect fit.
If I remember correctly we had to modify one bracket to make it a left/right application, but I don't remember if it was simply drilling holes or if welding was involved.
Sheepdip is offline   Reply With Quote
Old 11-29-2019, 05:33 PM   #4
HO455
HO455's Avatar
Re: air compressor
Welcome Aboard! If you look above you will see a search box. Type "air compressor mounting" in and click the 67-72 button. That will lead you to dozens of posts on mounting components. To further narrow the results click on images and happy searching.
You can mix it up some try a search for "air tank mounts"
Good luck!
RIP Bob Parks.
