Old 12-01-2019, 05:19 PM   #1
54blackhornet
54blackhornet's Avatar
Brake Light Reset ?
Can you guys explain how to get the brake warning light to turn off. I was told it comes on if the pressure in the two separate lines are not equal. I see no leaks and both sides of master are full...thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-01-2019, 05:36 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Brake Light Reset ?
Remove the wire from the switch in the distribution block
Remove switch from the distribution block
Pump the brake pedal hard a couple of times
Replace the switch and the wire...
The light should now be off
The switch trips over and locks out the brake circuit that has a pressure loss....check for brake fluid leaks around hoses, wheel cylinders and calipers etc
Hope this helps
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 12-01-2019, 05:39 PM   #3
54blackhornet
Thanks can you explain how to remove the switch ? Does it just unscrew ?
71 C-20
07 Magnum RT AWD
Old 12-01-2019, 05:45 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Remove the wire, it just pulls off
The switch just unscrews...use a box wrench...I think it is 9/16 or 5/8....you may even here the valve click back to center....
Pump the brakes a few times, then reinstall the switch and wire
2012 Chevy Equinox
