Re: K10 Shock Replacement
More info on rear shocks...
The rear shock mount (upper) is too big of an opening for a 3/4" bolt, so I enlarged the opening by using a rotary grinding wheel on a drill, then cut a thin piece of pipe with a 3/4" ID and inserted it into the frame opening. The bottom of the rear shock was a bit too wide so I just used a saws-all to take a 1/4" off both sides and then used a 3/4" bolt in the original frame mount.
Tance |
| Bookmarks |
