Old 12-03-2019, 04:02 PM   #1
72jimmy4x4
Shock mounts on 14 bolt
Putting in a 14 bolt in 72 jimmy. When it come to the shock mounts on the diff. One is forward on is facing the rear. Does the forward one line up? Or does it need to be cut and moved?
72jimmy4x4 is offline   Reply With Quote
Old 12-03-2019, 06:15 PM   #2
jjzepplin
jjzepplin's Avatar
Re: Shock mounts on 14 bolt
I just bought new shock mounts and mounted them as per the old 12 bolt. Works great. That was in 2000.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-03-2019, 06:25 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Hmmmm..
This is what i did.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 12-03-2019, 10:02 PM   #4
Mike C
Mike C's Avatar
I made a jig that bolted to the stock shock mounts on the 12 bolt and sat on the center section. I cut them off, cleaned them up, and welded them on the 14 bolt. A semi-float in the case of my truck. Used the jig again on my kid's Jimmy project with another semi float. I reused the 14 bolt shock mounts on it. I like the way the original 72 12 bolt shock mounts worked better FWIW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
