#1 | |
The Older Generation
Re: Thoughts on factory replacement tachometer
On my '67 Panel Truck with a stock tach dash & 2001 LS1 with the 411 PCM I just hooked the tach wire from the PCM to the tach output post on the back of the tach and changed the PCM resolution from 6 to 3 in the PCM tach settings. (that changes it from 8 cyl to 4 cyl) Seems to work OK.... No resistor needed and no changes to the tach. LockDoc Here is what lsnova said in another post: Quote:
I can't remember who posted this. If the tach is reading approximately half of what it should be, then you don't need the resistor. If the tach is barely or not moving at all then you need to put a 1K resistor from a switched power source into the tach feed wire. This will boost the signal. Now, back to reading half of what it should. The signal from the PCM is similar to what a 4 cylinder would produce. This is why you can switch aftermarket tachs to 4 cylinder mode and they read correctly. If the tach you have isn't switchable, you can have a tuner change the tach output in the PCM to make the tach read correctly. `
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-05-2019 at 08:52 PM. |
All this Hubbub about factory Tachos being “ Terribly Inaccurate” is BS.
The two that I’ve had (old and replacement) have both been within 25 RPM. If you’re racing? Go aftermarket. If not enjoy the factory stuff. How accurate are these “Factory” Tachs in the Muscle cars? |
#3 | |
![]() Join Date: Jul 2008
1965 c/10 swb 1969 c/10 lwb ![]() |
