#201 |
![]() Join Date: Aug 2014
Re: HP Tuners Tutorials - Chapter 1 - Logging
Key On - Vehicle Not Running - Systems Check
So first we look at the Engine Coolant Temp ok it's 57* F, so here are our thoughts:
looking below this Channel, at the next one Fuel System #1 Status says OL - Not Ready, our thoughts:
#202 |
looking at our next Channel, Barometric Pressure, our thought are
for now, the channel below Manifold Vacuum we just want to make sure it has a value, and it is as close to zero as possible Last edited by Gregski; 11-17-2019 at 11:52 AM. |
#203 |
now you may notice that the Barometric Pressure Channel reports in PSI instead of inHg (Inches of Mercury) hey that's Physics for you (seven different ways to say the same thing), and yes this is one of the things that you will do battle with in HP Tuners quite often, making sure you are comparing Apples to Apples and not Apples to Oranges type of thing, so simply right click that Channel select Units and choose the format you desire Last edited by Gregski; 11-16-2019 at 08:29 PM. |
#204 |
the Intake Air Temp channel is next, and this one can get skewed like in my case cause my truck has been parked in the shade all day so it shows a temp a few degrees below my iPhone Weather app So you knowing this, maybe use a local indoor outdoor thermometer barometer temp gauge thingie to get a better reading of the local air temp, or park your truck in a different spot, you get the idea Last edited by Gregski; 11-17-2019 at 11:54 AM. |
#205 |
Mass Airflow Sensor shows a perfect ready to go Key On engine not running reading of 0 hertz Last edited by Gregski; 11-16-2019 at 08:30 PM. |
#206 |
for the Engine RPM we just expect to see a value of 0 to prove the tach signal is coming through Last edited by Gregski; 11-16-2019 at 08:30 PM. |
#207 |
same goes for the Timing Advance channel we don't expect to see anything above 0 with just the key on and the engine not running, but seeing a zero is a good sign means we picked the right PID (Parameter ID) and there is a signal on the line Last edited by Gregski; 11-16-2019 at 08:31 PM. |
#208 |
and both O2 Voltage sensors are perfectly in the middle of .100 and .900 volts with the key on, and the vehicle not running Last edited by Gregski; 11-17-2019 at 11:55 AM. |
#209 |
now I would be lying if I told you I wasn't genuinely concerned about the low Control Module Voltage even if this is key on engine not running, something may be draining my battery here and low battery voltage can brick your PCM when you are flashing it |
#210 |
OK, let's use our Basic Channel config to evaluate the second of the three vehicle conditions:
1. Key on - vehicle not running 2. Vehicle Running - Open Loop 3. Vehicle Running - Closed Loop |
#211 |
Vehicle Running Open Loop - Systems Check
So now that the truck is running we see the presence of Manifold Vacuum, we observe that our value is now well above 0 We see a similar result for the Mass Airflow Sensor Obviously Engine RPM has climbed as well, though we don't know if it's where it should be yet, but that's ok for now, we are learning likewise we have a Timing Advance that is greater than zero Last edited by Gregski; 11-17-2019 at 11:56 AM. |
#212 |
now we see an interesting condition regarding our two O2 Sensors Voltage, it appears it went from middle of the road around .450 with the key on to above .900 with the truck running and warming up, later we will learn that this reflects a rich condition, but since the rig is warming up this is acceptable (think choke on) |
#213 |
and finally the Control Module Voltage looks much better, with the engine running, it is above 14 volts Last edited by Gregski; 11-16-2019 at 10:07 PM. |
#214 |
Lastly, let's use our Basic Channel config to point out the channel value differences in the final of the three vehicle conditions:
#215 |
I hope you stuck it out this far, as things began to get interesting. I pointed out earlier the importance of the Engine Coolant Temp and here is the first example of its cause and effect. When the temperature reaches 131*F notice what happens in the Fuel System #1 Status channel below it? The status changes from OL - Not Ready to CL - Normal CL meaning Closed Loop now. |
#216 |
lets take a deeper dive and see what exactly caused that switch from Open Loop to Closed Loop We know all of our configuration settings come from the VCM Editor so we fire it up and go to Engine \ Fuel \ Oxygen Sensors and look under the Closed Loop Enable heading where we find the ECT vs. IAT table (highlighted in pink for easier spotability that's all) We put our mouse over it, and glance at the bottom of the screen where we find the Context Clues, which read: This table sets the coolant temperature required to enable Closed Loop in relation to inlet air temperature (IAT). We open up that little guy, and it's not really a table as it is a list, but so be it. We quickly and easily see that once the ECT (Engine Coolant Temp) hits 131 (the big green bar) and our Intake Air Temp is above at least 50* we will turn on Closed Loop. Cool beans, so things are working as they should and now we know why. Don't take this for granted, someday you may be troubleshooting an issue caused by your PCM never entering Closed Loop mode, so just keep that in mind please. Last edited by Gregski; 11-29-2019 at 11:22 PM. |
#217 |
further down the list allow me to point out another cause and effect of you guessed it the Engine Coolant Temp The engine is a little warmer now, it has reached 154* F, it's time to cause another thing to happen... Note the drop in Engine RPM to approximately 550 |
#218 |
once again lets take a deeper dive and see what exactly caused the RPM to settle in at 550 so back to the VCM Editor we go (you will find this is the common Tango you will be performing whilst dueling HP Tuners ie. going to and fro from VCM Scanner to VCM Editor and back) Engine \ Idle \ RPM is where we find the Base Setpoint heading and the Base table lurks under it with our mouse hovering over it, we glance below to see: This table controls the desired idle RPM vs. Engine Coolant Temperature. This being an actual table and not a simple list, allow me to explain how I read it. There are four conditions:
So in our case in Park with the Air Conditioning off (deleted actually) and with the Engine Coolant Temp at 154* F we should be idling at 550, and we are. High fives all the way around! Last edited by Gregski; 11-17-2019 at 02:40 PM. |
#219 |
This concludes Chapter 1 - Logging
I hope I whetted your appetite for doing some tuning on your own or at least exploring the VCM Scanner. If you have some channels you like to use to do your initial system checks that I have omitted please let us know, we're all here to learn. |
#220 |
![]() Join Date: Jan 2011
I have been following along the entire time and have learned a lot. Thanks again for doing this.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#221 |
Re: HP Tuners Tutorials - Long Term Fuel Trims Short Term Fuel Trims
Long Term Fuel Trims and Short Term Fuel Trims, yeah we all heard the terms or the four letter acronyms LTFTs and STFTs, but what are they really?
A long time ago a teacher I had would tell us to substitute a word for a term we did not know instead of defining it for us, and it worked, so let's try this, any time you see the word Trims substitute it with the word "Changes" So Long Term Fuel Trims become Long Term Fuel Changes and Short Term Fuel Trims become Short Term Fuel Changes You could also use the word Adjustments or modifications, or what ever you come up with that works for you. Now some may find the following analogy or example silly, but I think it works as we all can relate to it, plus everyone enjoys a good short story. So it's the first day of Winter and you have to get dressed for school. So you put on the usual a T shirt and some jeans (socks, shoes and underwear is assumed) so in other words your VE outfit your Volumetric Efficiency or standard outfit. On Monday you step outside and start walking to school, soon you find it's colder than you expected but you press on. Tuesday same thing you throw on a different T shirt but still just a T shirt and a pair of jeans and you head out, freezing your butt off all the way there. On Wednesday you step outside in your T shirt and a pair of jeans and you say screw this I am making an adjustment and you grab a jacket and put it on and zip it up to the top (there you just made a Long Term Fuel Trim) from here on out you will bring a jacket until the weather will get too hot again. You walk to school wearing that jacket but once you get to class you are sweating, you think nothing of it. Thursday you head outside in a T shirt, jeans, and jacket of course, but half way there you think I'm getting hot, I should unzip my jacket (A Short Term Fuel Trim change) you get to school and you are no longer sweaty like the day before, you think I think I got this Friday morning you put on your T shirt, jeans, and a jacket but you don't zip it up today, nope the Short Term Fuel Trim has now become part of the Long Term Fuel Trim baseline if you will now if you start walking to school and it gets too cold, starts raining or snowing, by all means you have the freedom to zip up your jacket again, making yet another Short Term Fuel Trim adjustment/change Last edited by Gregski; 02-21-2020 at 10:05 AM. |
#222 |
Just wanted to clarify something that had me tripped up for a while and may help you. The objective is to get us thinking, in a non biased way as realists.
Do you need a Wideband Oxygen Sensor AFR Gauge to tune? The short answer is no. The better answer is, it depends. I bring this up for two reasons: 1. We need to understand what is controlling what as the vehicle goes through it's operational phases in order to determine for ourselves which tuning method to use and why.Let me preface what I am about to say and tell you that I am not anti Wideband gauges I use them I run them in my vehicles, however there are Pros and Cons to using both methods. Tuning Using the Stock Narrow Band Oxygen Sensors PROSTuning Using Wideband Oxygen Sensor(s) AFR Gauge PROS... and please don't get me started on Mail Order PCM tunes!!! hee hee RECOMMENDATION: In the end I like to use both methods, aka the belt and suspenders solution, that way you can cross check your results and perhaps account for any discrepencies. Last edited by Gregski; 02-21-2020 at 10:06 AM. |
#223 |
I just received my HP tuner equipment in the mail last night. I will go back review the thread & make wire harness to power up my ECM so I can work on it on the bench while it’s raining. Until I get my engine harness reworked and my truck is ready.
#224 |
Is this for "Snow White" yer '71 4x4 2004 5.3L?
#225 |
Yes it is
