Old 12-08-2019, 07:28 AM   #1
03BlkZ
Where do I even start
Well my dad and I are going to start working his 70 C10 this week. My plans for the first day are to get it out of the shop where it has sat for almost 20 years. I want to get it out and give it a good bath and that will allow us easier access to clean up the shop a bit also to make more room. I would like to get it back in the shop and get it on some jack stands to start evaluation. From then we will decide how we want to proceed. Should be a good time working on this with dad but I a little overwhelmed on where to even begin. I kind of want to take it down to the frame but I think dad just wants to make it safe and reliable to drive again. It will have to be a compromise between us since we are splitting the cost of everything. What would you guys do? Definately the bed rails, headache rack and brush guard will be trashed. I'm excited to get started and learn alot from all the knowledge here. Thanks,
Brent
03BlkZ is offline   Reply With Quote
Old 12-08-2019, 09:24 AM   #2
doo142
doo142's Avatar
Re: Where do I even start
To keep it fun and to not get burned out work on one area at a time and keep the truck operable. Get it running then stopping. Then maybe one side floor board rust repair. Then you and pops can take it for a ride and enjoy it while your working on it. If it’s totally torn apart it gets really expensive and no reward of driving it, that is overwhelming and will burn you guys out. My .02$
72 Cheyenne k/20, Custom Camper
72 Cheyenne k/20
71 blazer K/5 2WD 454, 6 sp.
67 Chevy Napco c30 Dump
56 GMC Napco 4x4 short step
66 Chevy K10
68 Chevy C/30 4x4
doo142 is offline   Reply With Quote
Old 12-08-2019, 09:30 AM   #3
jaros44sr
jaros44sr's Avatar
^^^ I agree, except, DON'T throw out any parts, the brush guard may be desireable to other people, I've seen them go for a considerable amount of money on the for sale board. I've been working on mine for 20 years, wish I didn't take it apart
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-08-2019, 10:09 AM   #4
Mike C
Mike C's Avatar
That brush guard is the "Smash Hit" and is the same as the one on my short step. It was made right there in Waco by The Perry Company and it is SOLID steel bars no wimpy tube. Looks like it may be tweaked a little on drivers side but you may want to keep it. I was going to ditch mine but the lower braces modify the grill surround so I decided to keep it and it has grown on me.
Truck looks like a good solid project. Decide what your goals are for the truck and start by cleaning it up. Wash the outside, vacuum the inside and start fixing things you need to reach your goal!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-08-2019, 10:55 AM   #5
notsolo
notsolo's Avatar
Search CLR....after you wash it, scotch bright and CLR....let it sit a while and rinse. Sweet project.
notsolo is offline   Reply With Quote
Old 12-08-2019, 10:58 AM   #6
03BlkZ
I'm assuming you are talking about using CLR on the trim and grill along with the scotchbrite.
Old 12-08-2019, 10:59 AM   #7
03BlkZ
[quote=Mike C;8639335]That brush guard is the "Smash Hit" and is the same as the one on my short step. It was made right there in Waco by The Perry Company and it is SOLID steel bars no wimpy tube. Looks like it may be tweaked a little on drivers side but you may want to keep it. I was going to ditch mine but the lower braces modify the grill surround so I decided to keep it and it has grown on me.
Interesting Information about the brush guard. I will keep that in mind and maybe see about selling it to put money back into the truck.
Old 12-08-2019, 11:05 AM   #8
68bowtie
68bowtie's Avatar
^^^ This! (0000 steel wool on that beautiful original paint...) Then get it roadworthy/safe. Enjoy some rides together as you work on more. As mentioned above it’s amazing how easy it is to teardown, and end up with a never ending project.
Oh, and start a build thread so we can all watch. Awesome truck!
Old 12-08-2019, 11:39 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
No, no scotchbrite on the trim and grille. Use the scotchbrite and CLR on the sheet metal only. Once you read the threads about it you will understand.
You will see some good threads on the subject if you type "CLR" into the Google search box at the top of this page, click on the circle in front of "67-72chevytrucks.com and click on the "Google" button. I think one of them says something about CLR & Scotchbright. It's amazing how well it cleans up rusty sheet metal.
Here is a thread with some pictures:
http://67-72chevytrucks.com/vboard/s...d.php?t=503608
Looks like a nice short bed project.....
LockDoc
Leon
Old 12-08-2019, 11:45 AM   #10
03BlkZ
LockDoc
Thanks! I was just watching some videos on youtube. I may have to give that a try eventually. Maybe try a spot this week and see how in comes out.
Old 12-08-2019, 11:46 AM   #11
03BlkZ
The grill appears to be aluminum is that right? I was wondering how hard it would be to polish.
Old 12-08-2019, 11:51 AM   #12
LockDoc
LockDoc's Avatar
The grille and trim are aluminum but it has an anodized finish on it. The anodizing would have to be removed before you could polish it. I don't know how bad it is but I would try some Turtle Wax White Polishing Compound on it first.
LockDoc
Leon
Old 12-08-2019, 12:05 PM   #13
JDL
JDL's Avatar
Change all fluids antifreeze, engine oil brake fluid, trans oil and rear-end. check brake shoes and wheel cylinders and pack wheel bearings.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 12-08-2019, 02:29 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
I didn't go look at the links, but I'd think that the white Scotch-brite would be the one to use. The green is pretty aggressive.
~Steven
Simi Valley, CA
Old 12-08-2019, 02:39 PM   #15
Bigdav160
Bigdav160's Avatar
A very high percentage of "frame off" projects never get finished.
First one? The percentage is even higher.
Get it running, stopping, driving and enjoy owning the truck.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-08-2019, 03:16 PM   #16
54blackhornet
54blackhornet's Avatar
Brent I would suggest you think again about removing all the aftermarket items your father installed. Those things where an investment he thought necessary to protect it. As others have stated get her running first safely and do one project at a time. Lots of us get a chance to work on dads old truck AFTER he passed, you get to while he’s still with you, enjoy the time together...
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-13-2019, 11:04 PM   #17
03BlkZ
So update on our new project. We got her out of the shop this morning to make an attempt to try and clean up the shop to allow more room to work. We hauled off two full truck loads of junk so it was a start. This was the first time it had seen sun in about 20 years and I felt good to get to out. We both wanted to remove the bed rails and headache rack so while dad was sweeping in the shop I yanked off. I decided to go ahead and give it a good wash to clean up some of the 20 years of dirt on the paint. We moved it to the other bay of the shop where she will sit while being worked on. I am excited to jump in on tjeis project and I am on vacation until 2 Jan so I have some time to spend going over all aspects of the truck so we can decide on a game plan. Here are a few more pics!
Old 12-14-2019, 01:12 AM   #18
randy500
You didnt say it was a short bed and it was hard to tell when it was stuffed the the garage, cool truck and a bit odd i think being a short bed and that smash hit grill guard on it.
Thats a very desirable and valuable grill guard.
randy500 is offline   Reply With Quote
Old 12-14-2019, 01:13 AM   #19
randy500
Post a SPID pic
Old 12-14-2019, 08:41 AM   #20
03BlkZ
Originally Posted by randy500 View Post
Post a SPID pic
What is a SPID pic? Unfortunately the fruck is about 45 minutes away at my parents house and I won't be back that way until Monday.
Old 12-14-2019, 09:53 AM   #21
jjzepplin
jjzepplin's Avatar
It is an option label on the inside of the glove box. MAN those pics are BIG!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-14-2019, 10:39 AM   #22
03BlkZ
Will do. I saw it on the glovebox door yesterday.
Old 12-14-2019, 11:00 AM   #23
68panelman
68panelman's Avatar
A lot of elbow grease polishing and waxing and you'll be very surprised with the results.
68panelman is offline   Reply With Quote
Old 12-14-2019, 11:19 AM   #24
vitamin_c95
I also have a project I bought off my neighbor. It did not run but he was slowly getting it there. The tanks and fuel were already purged and a new edelbrock intake and carb. I would love to do a restore but at the same time don't want to take 20 years to do it. In my case, im.calling it the rolling restore. I made.it run, and looking to get it road worthy so I can drive it when I want.. I am fixing and replacing parts as I go.
What I am saying is, basically go his route and get it driveable and fix as you go. Fresh fluids, get it running, fix leaks and go from there
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 12-14-2019, 03:22 PM   #25
Jason Banks
Jason Banks's Avatar
Keep that left front 8" - 6 lug - 4 nub - steelie! That's $100+ all day long.
Jason Banks is offline   Reply With Quote
