Re: 2.5 easy questions!
1. The best one is one you make the way you like. (You can choose where you will place your AC lines.)
1.5 This is a fairly common mod with customs. Here is a pic of my channel cut down, not boxed. Just search shaved, or smooth firewall. How's your build going? I haven't seen any updates in a while....
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#2 | |
Thanks for the info all!
I took a month off; lots of other projects including ones the wifey and work want me to do. ![]() I searched but didnt see much on the process. I cut off the lip (quick and easy with help from my friend Mr. Plasma; didnt even pull the hood!). Im planing on capping the top with a 3/16 strip to cover the panel laps and welding it in unless someone tells me to do it some other way. Now on the hunt for a GEN III! ~JH |
![]() Join Date: Dec 2013
Ahh , Geeezzz, Now you went and did it .... Say goodbye to your wife , add a micro wave and fridge to the garage a futon is optional , Notify your credit card company about the Huge # of forthcoming charges and to only send copies of receipts to your NEW secret email address .
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() My chrome shop just happened to call today on my girls day off with my balance ... Let's just say I'm getting the "stare" as I type this . LOL ! The process ... Only disassemble as much as you can afford to rebuild . Then double the time you think it will take .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-09-2019 at 10:08 PM. |
