Old 06-14-2004, 08:43 AM   #1
68_Step
Question Spark plug boots: 90 degree or straight
I am going to buy a new set of plug wires and am trying to decide which boot style to get. I have a 68 SBC (the one in my signature line) with ram horn exhaust and it looks like straight boots would clear nicely. I will be using Morosco wire looms that bolt to the valve covers. Any pros or cons for the styles?
68_Step is offline   Reply With Quote
Old 06-14-2004, 08:56 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I perfer to use the wire's for a 75 corvette as they are really long and have straight boot's...
FRENCHBLUE72 is offline   Reply With Quote
Old 06-14-2004, 10:53 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Yup, those are the ones to get if you have an HEI and rams horns. Here is a pic of them routed in the stock fashion.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-14-2004, 11:55 AM   #4
crazy longhorn
Fabricate till you "puke"
routed under , as in CPNE's pic is IMO much cleaner than over the top....a little more work to set up, but I ran the last couple with rams horns that way CPNE, is that edelbrock carb a "stock resto" item.....you are slippin dude! just "razzin" like always crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-14-2004, 12:05 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
The only thing I've ever "fabricated" is the myth that I actually believe anything other than stock is wrong.
Please note however, the engine is in the "correct" V8 position and my stock clutch linkage works very well. :p
Old 06-14-2004, 01:44 PM   #6
rambler
MOVE OVER
rambler's Avatar
those boots dont look straight in the pics... Did you get the 75 Vet boots and bend them yourself?
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-14-2004, 02:04 PM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
Ok, we all knew Jeff was a bubble off plumb, now we know he is also 90 degrees off too.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-14-2004, 02:23 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Around here 75 Vettes have 90 degree boots, or at least NAPA says so. Regardless, the key here is the length which allows for routing behind the block and under the manifolds. I don't think the boot really makes one bit of difference in this application. If they had to come over the top of the exhaust manifold, then obviously straight boots would be the way to go.
If you don't have HEI, then wires for the stock 67-72 SBC points ignition should work too, as they were designed to route in the same fashion. The 75 vette thing comes into play when you upgrade to HEI andwant to keep same routing as a 75 vette had HEI and ustilzed rams horn manifolds.
Old 06-14-2004, 02:36 PM   #9
crazy longhorn
if you think the stock clutch linkage works good.....you should try that "redesigned" linkage on my longhorn :p crazyL
Old 06-14-2004, 04:05 PM   #10
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
If you're gonna run headers, go with straight boots. Right now I have an HEI with straight boots on mine with stock exhaust manifolds, but I ordered a set of headers so I'm all set for 'em.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-14-2004, 07:49 PM   #11
cableguy0
most times the header tubes are in the way of using straight boots you will probably cook those straight boots and never be able to route your wires when you put the headers on you will see what im talkin about
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-19-2004, 12:31 PM   #12
68_Step
I think I will be keeping the ramhorns for a while... I just ordered a set of straight boot wires. Thanks!
Old 06-20-2004, 06:32 AM   #13
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a set of Accel's generic V8 HEI wires(straight boots)
I run 2.5" Corvette rams.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
