Old 12-07-2019, 10:34 AM   #1
stomper
Junior Member
stomper's Avatar
D49 Sport Mirror Brackets
I'm having a heck of a time finding just the mounting bracket and gasket for the little sport mirrors for our trucks. I read on a post that they were the same as a 69 Camaro so I ordered kits from Summit. No go. Anybody have a source for just the brackets that is certain to fit? Part number on the arm is 9826594. This comes up for 73 Chevelle (and others depending on which site you're lookin at) . Looks like they had different mirror heads but the same base. however cannot find just the mounting kit. help!
Title for this assembly would indicate it would work but pic does not reflect that for sure. https://www.ss396.com/chevelle/MHQ-7377.html
79 Silverado posted a great pic of the entire mounting assembly about 6 years ago. (shown)
"I was patina when patina wasn't cool."
1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-07-2019, 09:35 PM   #2
1774btcrew
1774btcrew's Avatar
Re: D49 Sport Mirror Brackets
Do you already have the inner support bracket? Black metal piece in the last picture?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 12-07-2019, 09:41 PM   #3
stomper
Junior Member
stomper's Avatar
no I just have two mirrors and that's okay I think it would be fine without the black inner bracket anyway
Old 12-07-2019, 09:42 PM   #4
1774btcrew
1774btcrew's Avatar
Mine seemed to shake a lot more without them. Also, you are less likely to have the screws pull through the door if you use them
Old 12-07-2019, 09:44 PM   #5
stomper
Junior Member
stomper's Avatar
Yeah if a kit came with the inner brackets I'd install them but if I just found the outer brackets I'd call it good
Old 12-07-2019, 09:46 PM   #6
1774btcrew
1774btcrew's Avatar
I would see if you can come up with used brackets before buying new. The reproductions are thin and IMHO don't compare to OEM. I think the gaskets are the hardest to come by.
Old 12-07-2019, 11:43 PM   #7
stomper
Junior Member
stomper's Avatar
I'm open to either. Cannot find.
Old 12-09-2019, 12:07 PM   #8
stomper
Junior Member
stomper's Avatar
Bracket (Retainer) is GM #9826886 and gasket is GM #9829666
Old 12-09-2019, 08:53 PM   #9
stomper
Junior Member
stomper's Avatar
Maybe found some brackets here:
http://www.pontiacparts.net/Body/page39.htm
No pix tho, and for $40 might as well get a whole new kit and sell mine as 69 camaro mirrors.
Old 12-09-2019, 11:22 PM   #10
Bandit130
Bandit130's Avatar
I replaced mine 2 or 3 years ago and still have the old ones. I will look for them and see what I have. If I have something usable, I will let you know. Bad weather expected here tonight and tomorrow but I will try to look anyway.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 12-10-2019, 02:57 AM   #11
stomper
Junior Member
stomper's Avatar
Thanks Bandit! LMK
Old 12-10-2019, 06:46 PM   #12
Bandit130
Bandit130's Avatar
This is what I dug up that I have left. I believe I used the black plates when installing new mirrors. These are the originals that I removed. These will work without the black plate that is on the inner door. But , I would find some type of plate and drill holes then use small bolts with washer, lock washer and nut to secure to the door skin. I think that if you only use metal screws into door they may loosen over time and will not hold securely. If you want these, PM me and I will only take shipping for them cause I don't think I would ever use them again.
Mopar by Birth
Chevy by Choice
Old 12-10-2019, 07:51 PM   #13
stomper
Junior Member
stomper's Avatar
Bandit you Sum *****, that's awesome! PM'ing
