Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 12-11-2019, 12:56 PM   #1
calvin78612
calvin78612's Avatar
Tools you can't live without
Here is one of mine. If you work alone it's handy for sure.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 12-11-2019, 05:47 PM   #2
Re: Tools you can't live without
You got a plan on how it was made or where you bought it? I am alone alot and could use something like that also.
Old 12-11-2019, 08:00 PM   #3
100%Chevy
LIKE!(a lot)
I last used my engine lift to pull and replace the heads and intake on one of my 454's in the car.Sure is easier on my old back!
Mike.
100%Chevy is offline   Reply With Quote
Old 12-11-2019, 09:34 PM   #4
Getter-Done
Getter-Done's Avatar
Great Idea.
The early bird gets the worm,
85 Chevy K-20
Old 12-11-2019, 09:35 PM   #5
calvin78612
I bought the plans from board member Rokcrln. Do a search for cab & bed lift and it should be the first result that comes up.
84 step side
87 swb
Old 12-12-2019, 01:50 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I've really loaded up on tools due to my project truck, but my favorite tool remains a good shop blower/vac.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-12-2019, 04:04 AM   #7
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
My favorite tool is one that I can find when I need it.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 12-12-2019, 06:20 AM   #8
I've heard of "third hands" before, but that's an extra pair of arms! I work alone . Makes me think of that George Thorogood song .
My answer to the title is "All of them". I buy them because I need them and tools are one thing I would never sell no matter how broke
Old 12-12-2019, 08:12 AM   #9
rpmerf
rpmerf's Avatar
I have a MityVac vacuum pump I use a lot. Has a pump like a bicycle pump and a body that hold 2 gallons of liquid. I don't like to get it dirty, so I will take various containers and drill 2 hoes in the lid. Hook one side to the pump, and the other side to whatever fluid I am trying to pull. Makes moving fluids around a lot easier. Some examples of great uses I have found.
Draining the radiator by vacuuming the fluid from the fill hole. No more dumping all over the place and trying to catch it.
Draining fluids through dip sticks when I don't have a drain plug. Worked really well sucking out a bunch of trans fluid before pulling the pan. Works good with lawn equipment also.
Useful for bleeding brakes.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-12-2019, 09:17 AM   #10
rsavage
rsavage's Avatar
At my age (68) I find that my lift and transmission jack are my two most valuable "can't live without" tools.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-12-2019, 10:50 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
That damned 10mm! Has anyone seen it?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-12-2019, 11:06 PM   #12
rsavage
rsavage's Avatar
I have trouble finding an 11mm. Doesn't seem like they are regularly included in metric combination wrench sets. Only have one use for them in spring and fall as the bolts that bolt my cab enclosure to my Kubota require 11 mm.
1961 C1 Corvette
2021 Durango RT 5.7
Old 12-13-2019, 01:35 AM   #13
franken
Hammers
Old 12-13-2019, 07:10 AM   #14
Getter-Done
I have noticed that also they have eliminated some sizes.
There is only 0.005 inches difference between 7/16" and 11mm. if that helps you.
Here is a Link below that has a chart for the sizes.
Link: http://www.csgnetwork.com/wrenchsizetable.html
85 Chevy K-20
Old 12-13-2019, 07:36 AM   #15
richard2717
Equal opportunity joke ofender
richard2717's Avatar
My Bobcat is still my tool I use most and could not imagine being without it for any length of time
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-13-2019, 08:47 AM   #16
A1971Blazer
A1971Blazer's Avatar
Bobcat 863
Two post lift
Top side creeper
several CNC lathes and mills
Band Saw
Welders
Pecker
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-13-2019, 01:34 PM   #17
1976gmc20
Well apparently the new tool that I cannot live without is a large (maybe 5/8 or 3/4 ?) allen wrench to check the oil in the five speed of my 1989 K1500
Everything else I've ever seen is either hex or square head plug, or else a square hole for a 3/8 or 1/2 ratchet extension.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 12-13-2019, 07:53 PM   #18
68C15
blood type; Retumbo
68C15's Avatar
That would be a 17mm. I have onenthat fits either a 3/8 ratchet or 17mm box wrench
Old 12-14-2019, 09:42 AM   #19
richard2717
forgot the more important one nowadays
Members I have met.
Old 12-14-2019, 12:47 PM   #20
1976gmc20
So about 11/16". Now I have to drive 50 miles round trip to town in another vehicle and see if the only parts store in town has one. I better call them first so they can order one. It's only been about 1000 miles since it was serviced but quite a bit of time as I don't drive it much, and you never know with old pickups.
Yeah, I had cataract surgery and lens implants a year ago. Great distance vision for the first time in ~55 years but can't see much of anything within about three feet without glasses - actually can't see that much with them. Mechanic work is hell because nothing is ever the right distance for either the main or add lens.
Old 12-14-2019, 01:35 PM   #21
68bowtie
68bowtie's Avatar
Seriously I think it’s this one. Home made. Lol!
I really like that one man hood removal idea!
Old 12-14-2019, 02:34 PM   #22
cornerstone
cornerstone's Avatar
This one comes to mind, but there would be a big ol list if I really thought about it.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 12-17-2019, 08:53 PM   #23
kingsolver72
10/30/19
kingsolver72's Avatar
I’ve had this kicker pick for close to 32 years.
I could live without it but, it’s handy. I think that I’ve had it longer than any other tool.
I’m pretty sure the duct tape is holding it together. I don’t remember when I put it on.
Been through a few knee kickers, power stretchers, straight edges, seam irons and trackers.
kingsolver72 is offline   Reply With Quote
Old 12-17-2019, 10:45 PM   #24
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
We all recently got emergency kits for our cars, in case of an evacuation (why we would evacuate from where we are is a continuing mystery to me- anything catastrophic enough would have killed us first). My wife told me that I had to put medication in that kit, sufficient for some amount of time. I don't have any condition that would be life-threatening in less than about 20 years. Go figure.
As far as any tools I can't live without, there aren't any. I use all kinds of tools. I cross-train those things for multiple use. It's amazing how well a crescent wrench will substitute for a hammer, for example. It's all I use them for, damned knuckle-busters, anyway!
~Steven
Simi Valley, CA
Old 12-17-2019, 11:25 PM   #25
Softpatch
Softpatch's Avatar
I would be lost without a welder
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
