Old 12-14-2019, 10:49 PM   #1
Driver_WT
Driver_WT's Avatar
Longer 5/16" Clutch Head Bolts
Can anyone point me to a source for 5/16" by 1.5" stainless steel clutch head bolts.
thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 12-14-2019, 11:09 PM   #2
mick53
Re: Longer 5/16" Clutch Head Bolts
That's a hard one. Maybe call McMaster Carr?
mick53 is offline   Reply With Quote
Old 12-15-2019, 10:55 AM   #3
Dachshund
Why...O.. WHY...? Not one of the greatest things GM thought about using. IF I get them out in one piece (without stripping it), then it goes in a "dead pile" and is replaced with something that is actually useful.
That said, McMaster-Carr MIGHT have some, or Paul B......
Dachshund is offline   Reply With Quote
Old 12-15-2019, 10:57 AM   #4
Driver_WT
Driver_WT's Avatar
Not on the McMaster Carr website (that I could find). I have these bolts for the rear fenders, but I need a couple of longer ones. I guess I could switch to button heads with an allen wrench. It is not like I am going for originality LOL
Old 12-15-2019, 12:20 PM   #5
joedoh
joedoh's Avatar
i just use hex bolts, but the wheeltubs hide all but the back two.
funny anecdote here: i used to spray penetrant and wait and try and take trucks apart saving the hardware. sometimes they would act like they would loosen and would get stuck, usually breaking or requiring me to cut. then I realized a box of 100 ea 5/16 hex bolts washers and nuts was 11 bucks. now I just set my impact screwdriver with 1/2 socket to tighten and almost every bolt breaks in less than a second. I took apart a 54 absolutely completely (including rear fenders and even the bed front panel) yesterday, the only bolts I undid without snapping were the hood and steering column. (doors were already off)
Old 12-15-2019, 03:29 PM   #6
_Ogre
_Ogre's Avatar
the only clutch head anything you'll find will be reproduction parts for chevy trucks and old tractors
best ss bolt selection i've found is boltdepot.com
i bought ss bed bolts in boxes of 100 for 30% of the ss bed bolt kits vendors sell
for fender bolts use truss head bolts with 50% bigger head
shipping will eat you up for small orders, try to order all you need at one time
shop air compressor timer
Old 12-15-2019, 07:40 PM   #7
mick53
If you just need a couple you could always TIG the head on a longer bolt.
Old 12-16-2019, 05:08 AM   #8
mr48chev
mr48chev's Avatar
You can probably find an allen head or torx head in stainless but I have never seen (or looked for stainless clutch heads.
My ongoing truck projects:
Old 12-16-2019, 05:53 AM   #9
Driver_WT
Driver_WT's Avatar
Thanks I will check out the truss head bolts
Old 12-16-2019, 05:54 AM   #10
Driver_WT
Driver_WT's Avatar
Thanks. I have stainless clutch head bolts now, just need a couple that are a little longer
Old 12-16-2019, 09:29 AM   #11
joedoh
joedoh's Avatar
my guess would be the top middle with the inside brace, and the two that pass through the angle strips. what made them need to be longer? i always fight that top one but only because the brace takes a bit to line up, use a clamp (if you have the bedsides cut, cant really find a long clamp if not) to squeeze it all together.
