Old 12-16-2019, 09:36 PM   #1
chev-obsession
chev-obsession's Avatar
Is this a van tilt column?
Hey guys,
To make a long story short I got this column out of a mid 70’s Chevy motor home for free today. I know it’s rough and missing quite a bit. Is this a tilt column? It’s not perfectly straight where the gear selector is and it has a few heavier springs inside and looks to have the horseshoe rod end. I couldn’t get anything to make it tilt. But I figured for it being free and 20 minutes of my time, I didn’t have much to loose
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 12-16-2019, 09:37 PM   #2
chev-obsession
Re: Is this a van tilt column?
More pics
1965 c/10 swb
1969 c/10 lwb
Old 12-16-2019, 10:21 PM   #3
70shortfleet
70shortfleet's Avatar
looks like one, need a picture of the lower part, could be a motor home tilt also.
70shortfleet is offline   Reply With Quote
Old 12-16-2019, 10:45 PM   #4
chev-obsession
Lower part of the column where it bolts to the steering box?
1965 c/10 swb
1969 c/10 lwb
Old 12-17-2019, 12:39 AM   #5
FirstOwner69
FirstOwner69's Avatar
Here's a picture of the 3 types of tilts.
Top- motorhome
Middle- truck
Bottom- van (picture this one without the fitting attached on the splines at the end of the shaft. I hadn't removed it when I took the picture.)
FirstOwner69 is offline   Reply With Quote
Old 12-17-2019, 01:27 AM   #6
chev-obsession
Top- motorhome
Middle- truck
Dang the motorhome and truck look identical!!
Do you know if there is a way I can activate the tilt in the column I have with all the levers being gone? I started pushing on the spring and couldn’t get the tilt to activate.
1965 c/10 swb
1969 c/10 lwb
Old 12-17-2019, 01:50 AM   #7
FirstOwner69
Here's a closeup that shows the difference between motor home and truck tilts. The motor home column has a bent transmission linkage arm and the neutral safety switch farther up the column.
Without a lever I don't think you'll be able to tilt it. I suppose a long bolt with the correct threads would work.
Old 12-17-2019, 02:43 AM   #8
chev-obsession
I didn’t see that little difference. I defiantly have a van column then. Now the task comes to see if I can get it to tilt...
1965 c/10 swb
1969 c/10 lwb
Old 12-17-2019, 09:51 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Is this a van tilt column?
Get some 1/4" x20 all thread rod or a 1/4" x 20 long bolt and screw it into the column. Put the tube in a vise and you may have to spray it down good with some kind of lubricate like WD-40 to loosen it up. From the rod threads on the steering wheel end any way.
Yep looks like a van tilt from the pictures.
Nice score for free though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-17-2019, 11:53 AM   #10
70cst
70cst's Avatar
Top- motorhome
Middle- truck
Excellent - Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-18-2019, 02:03 AM   #11
chev-obsession
Thanks for your guys input!! I was able to get a bolt into the tilt mechanism and activate the tilt, she needs a rebuild but that’s a project for another day.
1965 c/10 swb
1969 c/10 lwb
